Hi Troy,
Sorry for not getting back to you sooner. If you want to jog the axes assigned to the right thumbstick, here is an example:
Assign Right Stick - Side to Side as "Select Z Axis"
Assign Right Stick - Up and Down Axis as "Select A axis"
Assign X Btn as "Jog - Right Stick Side To Side"
Assign B Btn as "Jog + Right Stick Side To Side"
Assign Y Btn as "Jog + Right Stick UpDown"
Assign A Btn as 'Jog - Right Stick UpDown"
Now when you move the Right thumbstick, it will move at regular speed as before. When you want to jog, you press the A, B, X or Y buttons accordingly (leave the thumbstick alone) and the axis will jog accordingly. I may look at an alternative way of doing it after Christmas.
Lee
