Hello Guest it is March 29, 2024, 09:55:08 AM
Author Topic: MachScreen releases  (Read 147214 times)
Re: MachScreen releases
« Reply #90 on: August 03, 2013, 07:31:12 AM »
Thanks Klaus! Your like the gift that keeps on giving.  :)
« Reply #91 on: September 03, 2013, 12:16:48 PM »
Hello,
MachScreen V1.59 is ready for download. Changes:
MachScreen could hang on WinXP in Editor-mode, fixed.
I added the button "Function Code" on the property Dialog box. This button opens a window to show the functoin codes.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #92 on: September 03, 2013, 01:55:25 PM »
Thanks Klaus!
Offline khalid
  •  213 213
    • My Wood carving
« Reply #93 on: October 30, 2013, 10:32:41 AM »
Thank you Klaus for all of your hardwork and GIVING to the community.
« Reply #94 on: April 08, 2014, 03:44:31 AM »
Hi MachScreen users,
Version V1.61 is available.
Fixes:
"Persist. data editable on all pages" checked and selecting all elements, does not include page 0 elements when working on page 50.
New:
Every time a screenset-file is loaded, MachScreen checks width and / or height for 0. The found elements are shown in a report. The user has the following options:
delete, the selected elements are deleted
expand, the selected elements are shown in a larger Size.
ignore
In cases where many elements selected, it's often hard to find the selection hotspot to drag. Holding down the F2 button makes the selection hotspot flash.
Klaus
Offline rcaffin
  •  1,052 1,052
Re: MachScreen 6.1
« Reply #95 on: April 08, 2014, 04:23:15 AM »
Hi Klaus
Thank you.
Roger Caffin
« Reply #96 on: April 08, 2014, 06:18:53 AM »
Thank you Klaus for all the marvelous work you've done so far.
« Reply #97 on: April 03, 2016, 07:47:15 AM »
I released MachScreen V1.65. In that Version I've added a new feature. Under Menu: "Options -> Show / save all scripts" you can view all called scripts from the selected pages and save them to a disk. The filenames are built from the values of the Listview table. Special characters are replaced by a '+' sign.
Offline rcaffin
  •  1,052 1,052
« Reply #98 on: April 03, 2016, 05:18:01 PM »
Thank you.
Roger
« Reply #99 on: April 04, 2016, 06:36:39 AM »
Thanks as always Klaus.
The script function is a nice option and appreciated.
