Hello Guest it is October 24, 2026, 06:15:51 PM
Author Topic: Lacycam export to mach3 issues  (Read 9951 times)
Offline vadude
  •  18 18
  • WYSIWUG
« on: September 12, 2009, 08:56:20 PM »
I have a licensed mach3 with an unlicensed lazycam.I am able to upload a dxf file with a rectangle drawn in it to Lazycam.I inserted a text " test" into the rectangle & then deleted the rectangular outline.
I see the file as fomatted corectly in Lazycam/.However after loading it successfully into mach3,all i see 2 more chains added to my only chain 0 and a series of vertical & horizontal lines without the text that i am after.
   When I tried to cutting it,i see the machine trying to cut a pocket to the size of the rectangle without the rquired test.What am i doing wrong here?
No Pain No Gain
Re: Lacycam export to mach3 issues
« Reply #1 on: September 12, 2009, 09:27:13 PM »
See the "TUTORIAL #4 - TEXT" in the manual. The manual is in the members Docs. Text is also covered in the video.
