Hello Guest it is April 19, 2024, 08:57:32 PM
Author Topic: nd:yag pulsed laser system with mach3  (Read 10788 times)
« on: September 11, 2009, 05:16:58 PM »
Hello from Bulgaria  ;) ,
Just finished project: 150W nd:yag pulsed laser system for sheet metal cutting.
single lamp, single rod, water cooled gold cavity laser head, IGBT driven CCPS and PFN.
Repetition rate: 10-120Hz
Pulse duration: 0.5-2ms
Pulse current: 100-300A
Beam size: 0.15-0.20mm
XY Table size: 510 x 510mm
Power: 3x380V 20A
Builded from zero for 60 days.
Cut metal as follow:
Ordinary sheet steel up to 2mm
Stainless steel (304L, 316L) up to 2mm
Brass up to 1.5mm
Aluminum up to 1.5mm
Gold and Palladium up to 1.5mm
Silver up to 1.2mm
Re: nd:yag pulsed laser system with mach3
« Reply #1 on: September 11, 2009, 05:25:42 PM »
That is slick.  What would it take to cut up to 10mm of aluminum?
  •  9,198 9,198
« Reply #2 on: September 12, 2009, 05:30:08 AM »
Nice machine you have built there Dimitar. Do you have a final build cost ?.
Think it would probably take me 60 days just to do the wiring.  ;D
« Reply #3 on: September 14, 2009, 09:57:26 AM »
Thank you people.
@Tweakie.CNC - The final building cost - nobody knows exactly, but its near 10,000 usd where the optic and optomechanic cost is half of that price. Yes, its not easy job and its take me from 7:00 in the morning till 23-24:00 in the night - nonstop - no weekend or other work.
@GAWnCA - The laser can not cut aluminium in passes like CNC router, so - its impossible to cut more then 1.2mm. For 10mm aluminium you need 5000W co2 laser and even some of that lasers are not able to cut more then 6-7mm... Many of them will require duraluminium and reject even to try simple aluminium. The main advantage of all nd:yag pulse lasers is not to cut anything thick. With beam size 0.15mm we are cutting  promotional items and gift from any metal in very small size and very precise. No other machine can complete that job. Take a look:
« Last Edit: September 14, 2009, 06:49:31 PM by dimitar_stoykov »
« Reply #4 on: September 14, 2009, 11:08:23 AM »
Those are nice objects you have cut.  I guess the CNC Mill is my only hope for cutting larger items from aluminum.
« Reply #5 on: September 14, 2009, 06:46:14 PM »
There is one other hope - waterjet...No thickness limitations. No problems with reflective materials such as brass and aluminum. No heat input, so there is no burning or heat-affected zone.
« Last Edit: September 14, 2009, 07:26:58 PM by dimitar_stoykov »
« Reply #6 on: September 14, 2009, 08:30:17 PM »
Where do you find the information on building a water jet?
« Reply #7 on: September 15, 2009, 03:41:19 AM »
Don't try to build it. You can't do that in your garage. but there is some not so expensive retrofit kits over here http://www.wardjet.com
« Reply #8 on: September 15, 2009, 10:52:25 AM »
Now that is cool and thanks for the link.!!
« Reply #9 on: February 27, 2016, 03:09:02 AM »
And more info and water jet machines: http://www.techniwaterjet.com/water-jet-machines/
