Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 22, 2013, 08:36:03 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
The Laser Project.
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
Go Down
« previous
next »
Author
Topic: The Laser Project. (Read 73159 times)
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Re: The Laser Project.
Reply #80 on:
April 28, 2010, 05:52:41 AM »
By way of an update on this project:-
The DRO struggled to display the tube current a low power settings and has been replaced by a retro moving coil panel meter straight out of the 1960's. A new scale was engraved with the laser and a suitable shunt fitted to calibrate the meter.
This is my first attempt with cutting acrylic. The red is 2mm and the clear is 6mm thick.
Success consists of going from failure to failure without loss of enthusiasm. Winston Churchill.
Dan13
Active Member
Offline
Reply #81 on:
April 28, 2010, 06:03:41 AM »
Very nice Tweakie!
6mm acrylic, now that's something! Could you take a better photo to show the cut edge? Just curious what kind of finish does it leave. Does it cut 90 degrees, or does it have a draft angle like with plasma?
Interesting photo, BTW, looks like a photo of a moving object with that blurred background.
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Reply #82 on:
April 28, 2010, 07:10:17 AM »
Hi Dan,
Yes it does have a draft angle because the beam converges from the lens to the exact focal point whereupon it diverges again. I am currently looking at ways to improve this situation either by using a lens with a greater useful focal length or multi-pass cutting at reduced power with Z movement resetting the focal distance on each pass.
The edge finish is not perfect with some vertical styrations similar to a bandsaw cut but at least it is polished and so looks acceptable - I need more practice and experience here !.
The picture was taken with flash and the acrylic is on a sheet of brushed alluminium - Quite a nice effect I thought !.
I will post some more pictures when the camera battery has been recharged.
Dan13
Active Member
Offline
Reply #83 on:
April 28, 2010, 07:33:56 AM »
Hi Tweakie,
A friend recently bought a plasma table which was claimed to cut 30mm steel with no draft angle at all. Don't know how it's achieved there and haven't seen the machine yet.
You might be better using a lens with a longer focal length and further away from the workpiece, so that the beam travels more distance to the workpiece surface. May be that's what you meant...(?) But then you already have your design constraints. Also, can you play with the point where the beam is focused? Do you focus it on the surface of the material? Can you focus it in the middle of the material thickness?
The picture does have a nice effect indeed
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Reply #84 on:
April 28, 2010, 09:27:10 AM »
Hi Dan,
Thanks for the suggestions / ideas - anything and everything is appreciated. I have just so much learning to do here.
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline
Reply #85 on:
April 28, 2010, 03:37:25 PM »
Wow wow wow! Nice looking stuff, my friend!
Love the old meter, nice touch
Dave->
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Reply #86 on:
April 30, 2010, 11:58:32 AM »
I had boiled eggs for breakfast this morning and while I was dunkin my soldiers I thought " I wonder if..... ".
The answer is yes you can.
Overloaded
Global Moderator
Offline
Reply #87 on:
April 30, 2010, 12:04:56 PM »
Cool Tweak.
How fitting.....is that a roadrunner egg ?
NEAT !
"I haven't failed. I've just found 10,000 ways that won't work." Edison
"You cannot help men permanently by doing for them what they could and should do for themselves."
Abe Lincoln
Tweakie.CNC
Global Moderator
Offline
Super Kitty.
Reply #88 on:
April 30, 2010, 12:14:15 PM »
I think I ate the roadrunner bit, that just left Wile.
Sam
THIS SPACE FOR RENT.
Global Moderator
Offline
Reply #89 on:
April 30, 2010, 01:12:18 PM »
Hehe...that's funny. Your brain sure works in mysterious ways. I wonder if you burned around the circumference, would it crack perfectly. There's a million dollar invention for ya....perfect crackin' eggs.
"I sometimes think we consider the good fortune of the early bird and overlook the bad fortune of the early worm." FDR - 1922
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
