Hello
Guest
it is
March 19, 2024, 06:59:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
General CNC Chat
Show"N"Tell ( Your Machines)
The Laser Project.
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
Go Down
Author
Topic: The Laser Project. (Read 1191525 times)
Chaoticone
5,624
Precision Chaos
Re: The Laser Project.
Reply #680 on:
October 06, 2012, 08:00:40 AM »
Tweakie, have you done any test or comparisons with the different woods and their surface finish, density and moisture content? I'm just thinking if those 3 variables were monitored maybe a formula could be created to give consistant results.
You do some of the neatest stuff Tweakie!
Logged
If you could see the things I have in my head, you would be laughing too.
Tweakie.CNC
9,195
Super Kitty
Reply #681 on:
October 06, 2012, 08:10:41 AM »
Hi Brett,
I had not even thought about measuring moisture content (I do have the equipment to measure that) but surface finish certainly does play a big part in determining the result.
Any thoughts or suggestions on the easiest way I can determine density ??
Logged
Chaoticone
5,624
Precision Chaos
Reply #682 on:
October 06, 2012, 09:07:48 AM »
I have used this before.
http://www.engineeringtoolbox.com/wood-density-d_40.html
I don't know how accurate that will be really because of growing variables but it should get you with in a reasonable range. You could also just measure and weigh and account for moisture content or its probably overkill but you could do a displacement vs weight test. Maybe vaccum seal the wood in a known size bag and sink it in a pan of water and measure the amount of water that gets displaced. I wouldn't think you would need that at all unless you were trying to measure odd shaped pieces.
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #683 on:
October 09, 2012, 07:00:10 AM »
Thanks for the info Brett, it is most helpful.
Overall the Obechi seems to give me the best results with, contrast ratio, so far but I still have a few more different woods here to try.
Logged
Dan13
1,208
Reply #684 on:
October 09, 2012, 07:17:45 AM »
Hi Tweakie,
Why are there vertical lines on the last one?
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #685 on:
October 09, 2012, 07:32:58 AM »
It's the grain of the wood Dan.
Logged
Dan13
1,208
Reply #686 on:
October 09, 2012, 07:40:59 AM »
Ah... They are so evenly spaced and bright (I would have expected the grain be darker than rest) that it didn't occur to me it was the grain
Logged
Chaoticone
5,624
Precision Chaos
Reply #687 on:
October 09, 2012, 08:02:10 AM »
Tweakie, what are the physical dimensions of the piece in the last picture you posted?
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #688 on:
October 09, 2012, 08:24:38 AM »
Hi Brett,
It's 150mm x 95mm.
Logged
patter
18
Reply #689 on:
October 13, 2012, 03:50:57 AM »
WOW Tweakie.... the contrast is perfect....excellent
Logged
My blog.....
http://patrelief.blogspot.it/
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
Go Up
« previous
next »
