Hello
Guest
it is
March 19, 2024, 08:38:50 AM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
General CNC Chat
Show"N"Tell ( Your Machines)
The Laser Project.
« previous
next »
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
Go Down
Author
Topic: The Laser Project. (Read 1191573 times)
ntlaser
49
Re: The Laser Project.
Reply #400 on:
June 02, 2011, 09:05:56 AM »
doesnt make any sense.And why the double image is produced in the one axis(x) direction?I have to mention that my x axis has faster speed than the y axis!
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #401 on:
June 02, 2011, 09:07:08 AM »
Certainly a mystery.
Could you possibly post a picture of the result and a copy of the test image you are using please ?
Logged
ntlaser
49
Reply #402 on:
June 02, 2011, 09:09:12 AM »
I will make some samples and posted tommorrow,if this ok!Thanks you very much for your help.
Logged
ntlaser
49
Reply #403 on:
June 02, 2011, 09:15:05 AM »
could you post a simple test image that you have already tested and your plugin screen(settings).To make a sample on this?
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #404 on:
June 02, 2011, 11:07:46 AM »
Something like this would be good.
Say 30mm x 30mm, Stepover 0.5mm, Feedrate 20,000 (not inverted)
Last Edit: June 02, 2011, 11:13:25 AM by Tweakie.CNC
Logged
Tweakie.CNC
9,195
Super Kitty
Reply #405 on:
June 02, 2011, 01:52:24 PM »
This is the result I get from the above image settings.
The scan starts bottom left and it can be seen from alternate lines that there is a slight delay where the laser turns on and another slight delay where it turns off. This delay is so small that it makes no difference to the quality of photos or other images processed by the plugin.
Logged
ntlaser
49
Reply #406 on:
June 02, 2011, 04:29:14 PM »
I ll try it first thing tomorrow.
Logged
ntlaser
49
Reply #407 on:
June 03, 2011, 05:16:57 AM »
Tweakie good morning.These are the results.
1 st photo 30x30 0,5 20000
2nd only change the feedrate 7000
3rd feed 4500
Logged
ntlaser
49
Reply #408 on:
June 03, 2011, 05:20:35 AM »
here are the photos
Logged
ntlaser
49
Reply #409 on:
June 03, 2011, 05:25:52 AM »
As you see for 20000 the images are 2 and the power output is too strong(how I can modify the output?)
with 7000 the images come closer thats why you see totally burnt in the middle where the two imagew meet
4500 the same but here is more obvious.The black is where the two images meet..........
Logged
Print
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
Go Up
« previous
next »
