TEACKIE THANK FOR YOUR REPLY
THE "MANUFACTURER" TOOK PARTS AND ASSEBLIED THEM!! I HAVE 3 AC MOTORS 1000W EACH WITH THEIR DRIVERS "MAXSINE". THE MOTORS ARE OVER THE TOP AND TO TELL YOU THE TRUGH THEY ARE NOT NECESSARY TO BE SO POWERFUL!!! I AM FACING THE SAME PROBLEM LIKE YOU WITH THE WEIGHT OF MY BRIGHE X AXLE.~ 50 KG!!!!
STILL I DONT UNDERSTAND HOW I CAN MODIFY THE LASER OUTPUT
..MY LASER SUPPLY CAN MODIFY THE LASER OUTPUT BY PWM PULSE OR BY CHANGE OF VOLTAGE BETWEEN 0-5V..I READ IN THE MANUAL MACH3 THAT SUCH AN OUTPUT IS POSSIBLE FROM MACH3.
ANOTHER THING IS HOW ACCURATE IS THE MODIFICATION OF A DXF IN G CODE USING LASYCAM!!AND HOW CAN I STOP LASER BETWEEN THE CUT, FROM ONE PART TO THE OTHER.SHOULD I USE PLASMA MODE?
I WANT TO POST SOME PHOTOS!HOW CAN I DO IT? I AM TRYING FOR 3 MONTHS TO SET THIS MACHINE IN ACTION..
