I have it indexing at the same rate as the front turret did, I could go a lot faster if I wanted but no point in putting undue stress when it wont make that much difference. The setting in the drive is 1000rpm and accel/decel of 100 rps/s The motor itself is capable of 5000rpm and I could probably go well into the thousands on accel/decel.
Just finished redoing the ladder, quite a bit of work so hopefully I got it right
Good thing is if its not then can easily reload the previous one and rework this one although if it is wrong its likely just a small oversight and could edit in place.
Still have the macro to change but that shouldnt take long so hopefully tomorrow I will get a chance to load the ladder, load the new macro and connect the extra wire and have it indexing to all 12 slots instead of just the 6.
