Hello Guest it is April 25, 2024, 01:02:58 PM
Author Topic: Just got a lathe to retrofit  (Read 178307 times)
Re: Just got a lathe to retrofit
« Reply #230 on: February 05, 2012, 02:07:53 PM »
Got the main parts welded up, had to use 20mm thick for the sides rather than the 15 I had in the design as thats all I had that was long enough. That meant I had to have it protruding by 5mm either side of the back part but wont really matter.
With a bit of luck next week  I will get the outer sides cut and welded in, the  bush housings, bushes and shaft made up  and then it will be on to making the hydraulic cylinder.
« Reply #231 on: February 06, 2012, 03:25:34 AM »
It's getting heavy so moving it around the shop is getting a serious task ;)
« Reply #232 on: February 06, 2012, 05:04:16 AM »
Sure is Dan and its away to be heavier as the only steel I have for the sides is 1" thick, had planned on 15mm ;D
I suppose it being heavy can only be a good thing as it should make it more rigid.
« Reply #233 on: February 06, 2012, 06:16:43 AM »
Yep, Hood, it's only a good thing or at least as long as you won't have to reduce acceleration.
« Reply #234 on: February 06, 2012, 11:26:21 AM »
Shouldnt be a problem, the front post I took off weighed in at over 75Kg.
« Reply #235 on: February 09, 2012, 06:05:51 PM »
Not got much done except getting the outer sides welded on and welds ground flush(ish ;D ).
 Did however have a good look at the front turret today and did some measuring. I think I can reuse the shaft, cylinder, belt and pulleys I have on it so that will save a fair amount of work and some money :)
 I was wanting to keep the front turret intact just in case I find a need for it somewhere else but if I do then I can always make a new shaft and cylinder later on.
« Reply #236 on: February 11, 2012, 03:06:12 PM »
Made the mounting bracket for motor/gearbox today and then decided to pull the cylinder and shaft off the front turret so I could see what exactly I had to make up for mounting them. Decided I might as well just go the whole hog and pull the complete turret, hopefully I will get  the turret finished before I need to do any serious internal work. I still have two manual lathes that I use quite a bit but anything with tapers or threads, especially internally is much easier on the CNC.
 I mounted the motor/gearbox to the turret and offered up the shaft and cylinder to see how they looked, hopefully tomorrow I will get the bush housings made and may even get as far as mounting the cylinder.
Heres a couple of pics, my lathe looks bare without the front turret ;D
« Reply #237 on: February 11, 2012, 03:09:28 PM »
Oh also meant to say, I was surprised how small internally the cylinder is. I was planning on making a cylinder that had 1.5 tonne pull and was wondering if that would be enough, well this one works out at only 0.75 tonne and its worked great :)
« Reply #238 on: February 14, 2012, 09:41:24 AM »
Got a bit more done, got the bush housings made, bushes made, hyd cylinder mount made, cylinder fitted, belt, pulleys and motor/gearbox fitted.
Still have the shaft to cut shorter and make and fit a flange to attach to shaft/turret plate, bore/tap the mounting holes for the turret housing half of the curvic coupling and also have to mount the limit switches that detect the clamp/unclamp.
After that it will  be fitting it to the lathe, getting the final height and then dismantling and machining the base to the correct height, I am approx 1mm higher than it will be, I hope ;D.
Pic below of what I have done and my quality control inspection guy having a look, not sure if its got the thumbs (paws) up but he let me throw the ball for him just a bit later so looking hopeful :)
« Reply #239 on: February 17, 2012, 01:41:57 PM »
Getting closer, today I managed to make the flange for the shaft/turret plate coupling up and shortened the shaft and got it bored and tapped. Unfortunately the split nut on the back cracked right through whilst undoing it today so I will have to make a new one. Dont think I have a threading bar that is small enough to do a 20mm thread so will probably have to grind up a bit of HSS to do it. Once I have that complete I have the holes to bore and tap for the curvic coupling to main housing and then I suppose its time to remove the rear turret from the lathe and try and fit this one.
