Hello Guest it is May 10, 2024, 06:53:06 PM
Author Topic: When, Oh When, are we going to get backlash compensation?  (Read 13286 times)
Re: When, Oh When, are we going to get backlash compensation?
« Reply #10 on: March 19, 2012, 05:44:49 AM »
Thanks Dan,
So was the fix in Mach3 or was it in the SS?
As I probably have a very downlevel SS  :( I'm hoping it's a Mach3 fix.
Cheers,
Dave.
« Reply #11 on: March 19, 2012, 05:57:20 AM »
Hi Dave,
It was a fix in the SS plugin. Or to put it better - an addition of backlash compensation code to the SS plugin.
« Reply #12 on: March 19, 2012, 06:27:16 AM »
Thanks Dan,
I've just been looking at the plugin versions and info on the SS web site but I'm still not clear what plugin and Mach3 combo I should use. There is still a bunch of red text saying that they have discovered a problem and that we should use the Dev versions of Mach3 rather than the lockdown one.
So I assume that I use this plugin (SmoothStepperUSBDriver2.08.14.zip) with Mach3 Dev R3.043.059? Incidentally the Mach downloads web page lists the SS plugin as 1.19.********* - needs updating.
Many thanks.
« Reply #13 on: March 19, 2012, 06:39:00 AM »
Dave,
I'm using Mach3 Dev version 057 and SS ver 17cd and it works fine here.
« Reply #14 on: March 19, 2012, 06:55:25 AM »
Hi Dan,
You mean this one? (2011-05-21    PlugIn: SmoothStepper_v17d.zip)
It's not available for download anymore.
There are only these three available: 2011-10-30    PlugIn: SmoothStepper_v17efb.zip,
this: SmoothStepperUSBDriver2.08.02.zip
and this: SmoothStepperUSBDriver2.08.14.zip.
Anyways, it's going to be a while before I get my workshop operational and mill reinstalled and by the time I get round to it things may have changed so I'll keep my eye on things.
Many thanks,
Dave.
« Reply #15 on: March 19, 2012, 07:31:01 AM »
Dave,
This is the plugin I am using.
« Reply #16 on: March 20, 2012, 01:04:51 AM »
Thanks Dan, I've downloaded it, I'll hang onto it for later. ;D
Cheers,
Dave.
