Hello Guest it is April 19, 2024, 10:10:25 AM
Author Topic: It can change the interface of the wizard?  (Read 7305 times)
« on: August 01, 2009, 12:41:26 PM »
Hello to all. I can not change the files. Set in the Addons folder. It is not possible or am I wrong? Regards, Giordano Cantori
Re: It can change the interface of the wizard?
« Reply #1 on: September 11, 2009, 06:14:21 PM »
I do not understand your question, but one problem you may be seeing is that Screen4 does not get the path correct, so it does not display the bitmaps that are in  your bitmap folder.
The only way around this is to move the .set file and all its bitmaps to the Mach3 folder and to Mach3\bitmaps
I have asked Brian about this and he has tried to fix it but for some reason it is to deep into the Screen4 code to fix
« Reply #2 on: September 12, 2009, 04:41:45 PM »
Hello Ron. I created a new interface for Mach3, in Italian and English. I noticed that the wizard screens are a bit messy and I would like to modify them with the same style as the main interface. Regards, Giordano.
