Hello Guest it is April 24, 2024, 08:24:57 PM
Author Topic: New PlugIn just about done..  (Read 182571 times)
Re: New PlugIn just about done..
« Reply #20 on: September 02, 2006, 10:34:11 AM »
Oh, so it does need to be run on incremental? thats no fun. The faster you turn the wheel the faster the axis should go.
Jon
« Reply #21 on: September 02, 2006, 12:58:10 PM »
It will do that if you have it set to velocity mode :)
You were thinking you had me that time... NEVER HAHAHAHAHA (Evil laugh)  ;D
www.newfangledsolutions.com
www.machsupport.com
« Reply #22 on: September 02, 2006, 03:21:49 PM »
I have the orignal Shuttle Pro.  I enabled it on the config plugins page and setup a couple of buttons on too computers.  Could it be possible that the plugin does not work with the original shuttle pro?   I have a shuttle express too so I will test it with that as well and let you know.
David
« Reply #23 on: September 02, 2006, 06:01:13 PM »
Okay, it seems to be a problem with the original (silver) shuttle pro as my shuttle express works fine.
David
« Reply #24 on: September 02, 2006, 10:09:02 PM »
okay can you go to device manger and get the Vendor ID for the shuttle Pro? this will help to see if we can get yours running :)
www.machsupport.com
« Reply #25 on: September 03, 2006, 06:10:19 PM »
Hi Brian,  yes the vendor id is
"USB\VID_05F&PID_0240\6&242944A3&0&2"
David
« Reply #26 on: September 04, 2006, 12:52:40 AM »
I installed the PlugIn with Shuttle Pro.  It works great!
I couldn't find a drop down button option to cycle the jog increment from .1 to .01 to .001, etc.
Also, is there a way to jog just one increment.
Maybe too much to ask, but is there a way to use the plugin and then program the buttons to do whatever you want (vs. just what is in the drop down menus).
James Mossman
« Reply #27 on: September 04, 2006, 09:47:46 AM »
For you I think I can add i t:)
Look under config plugIn and click on the yellow config button for the shuttle pro. This will open up the settings for the shuttle pro
Also if you would like to change the jog Inc press the tab key in Mach3 and change the jog inc.
Brian
www.machsupport.com
« Reply #28 on: September 05, 2006, 10:58:39 PM »
Brian,
I got a shuttlepro for my b'day!  And I was using it but a little confused on how it was working.  When I use the inner wheel it takes a few clicks and then the axis moves a certain amount.  Is there a was to adjust the amount it moves?  The same with the outer wheel.  Can you adjust the rates the axis moves as you rotate the dial.
I have no specific need just wondering how it works.
Great job on the plugin.  You guys do some very nice work.
Dan.
« Reply #29 on: September 06, 2006, 07:43:41 AM »
There is an Inc mode and a velocity mode for the inner wheel... You can setup a button to change than on the shuttle.
The inc and slow jog amount is set by changing values on the 'TAB' screen. The outer wheel will take you up to the slow jog rate :)
BTW happy B'day
www.machsupport.com
