I'm having a rather frustrating problem at the very end of a long process. I created my design in Solid Works, then moved into Master Cam and now Mach 3. When I test the cutting pattern in Master Cam, everything looks correct, but when I go to actually cut out the design, it is perfectly inverted. Is there an inversion command that I'm missing?
I've noticed that in my g-code, all the x axis measurements are negative, which doesn't seem quite right. Also, I'm using a generic post-processor. Could this be the problem?
