Hello Guest it is April 19, 2024, 11:50:04 PM
Author Topic: Running Mach 3  (Read 8339 times)
Offline Soe
  •  1 1
Running Mach 3
« on: June 28, 2009, 07:43:24 PM »
Help! I am a starter having problem from the start. Mach 3 download is successful but the emergency stop will not reset. Uninstalled and re-downloaded 3 times and did not help. Please help with a solution.
Thank you
Soe.
Re: Running Mach 3
« Reply #1 on: June 28, 2009, 10:02:04 PM »
Have a look at the documentation in the support tab above.
Is this hooked to a machine? If your using it for simulation you can go to config, ports and pins, inputs and change the active state of the e-stop input. If it is wired to a machine you will need to find out the logic of the estop circuit and set it according to that for safetys sake.
