Hello Guest it is April 25, 2024, 04:14:54 AM
Author Topic: Help me  (Read 3356 times)
Help me
« on: June 23, 2009, 08:48:30 AM »
Is it possible to make screen as on picture?
Can anyone help me?
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Help me
« Reply #1 on: June 23, 2009, 04:43:44 PM »
Not sure what you are asking, but if you are having trouble "Jogging" the machine you will need to included a "Jog on/off" button.
Re: Help me
« Reply #2 on: June 24, 2009, 08:21:39 AM »
I don't know how to set Jog Increment for each directional button
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
Re: Help me
« Reply #3 on: June 25, 2009, 03:47:09 PM »
Grab the UserDRO's you have on your screen, then call on a Gcode command either adding to the current position using G90 or using incremental G91.
This is the idea, but you might need to check a number of things depending on your application to make sure the G0 call will be safe ;) and/or if you need to return the machine to a G90.
G91 Example:
Code: [Select]
amount_to_move =  GetUserDro(1000)
Code "G91 G0 Z" & amount_to_move
G90 Example:
Code: [Select]
amount_to_move = GetOEMDRO(802) + GetUserDro(1000)
Code "G90 G0 Z" & amount_to_move
Please first understand your machine and Gcode before running any code on your machine ;)
« Last Edit: June 25, 2009, 03:51:06 PM by zealous »
