Hello Guest it is April 19, 2024, 10:27:20 PM
Author Topic: VB Button: Pause and Raise Z  (Read 7665 times)
« on: June 18, 2009, 01:06:05 PM »
I am new to Mach3 and attempting to code the Pause button to stop the machine and raise the Z spindle height.  I am not very familiar with VB and am having trouble making the spindle rise after I have told it to pause... Any Ideas??
Anthony
Re: VB Button: Pause and Raise Z
« Reply #1 on: June 18, 2009, 01:42:31 PM »
Something like this will move the Z up 2":
DoOEMButton(1001)
While IsMoving()
Sleep 100
Wend
Code "G0 Z2"
« Reply #2 on: June 18, 2009, 03:36:09 PM »
Worked perfect!
Is there any way to change the delay between the time the pause button is pressed and when the machine actually halts movement?  There seems to be about a 1 second delay.
Thanks!
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #3 on: June 19, 2009, 11:57:49 AM »
Hi Anthony,
When you feedhold the machine the amount of time it takes to come to a stop will depend on your motor tuning Accel/Velocity.
You can either change this if your motors permit or use the "stop" (1003) rather than a "FeedHold" (1001)
« Reply #4 on: June 19, 2009, 12:26:23 PM »
Not being familiar with this I have to ask ! The code snippet above must function in incremental ? Will it still go up if you are cutting above 2" or will it go down to 2" ?
CRUISER
  Don
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #5 on: June 19, 2009, 01:02:15 PM »
Yes in ABS it will go down to 2 inchs...so if your machine is at 2.000 and you run the script the machine will just sit there ;)
If you are at 3.000 it will come down/up (depending on your machine)  to 2.000.
If you want to increament in ABS you can:
Code: [Select]
DoOEMButton(1001)
'Wait for machine to stop
While IsMoving()
Sleep 100
Wend
'Get current Z
current_Z = GetOEMDRO(802)
'Add 2' to z
inc_z = current_Z + 2
'Sent command you can use G1 as well if need
Code "G0 Z" & inc_z
« Last Edit: June 20, 2009, 06:38:08 PM by zealous »
« Reply #6 on: June 19, 2009, 01:38:20 PM »
Sorry, my mistake. Ideally, you'd check if the machine is in abs or inc mode, change to incremental, move up, then change back to whatever it was set to before.
« Reply #7 on: June 19, 2009, 11:10:34 PM »
So then Anthony M above, could have just as easily have crashed his machine ?
Curious indead !
Thanks for the Instruction
CRUISER
  Don
Offline zealous
  •  489 489
  • HI!
    • Artsoft Solutions
« Reply #8 on: June 20, 2009, 06:33:36 PM »
Thank you for pointing that out...that is my bad!
Code: [Select]
'FeedHold
DoOEMButton(1001)
'What mode are we in
mode = GetOEMLed(49)
While IsMoving()
Sleep 100
Wend
Code "G90 G0 Z2"
'If we have changed from abs to inc mode then change back
If mode = true Then
   code "G91"
End If
