Hello Guest it is April 24, 2024, 08:37:39 AM
Author Topic: How I made my pendant.  (Read 46858 times)
Offline Bengt
  •  54 54
    • Private CNC site
Re: How I made my pendant.
« Reply #60 on: April 22, 2010, 12:12:35 PM »
eloid
Have a look in the PoKeys manual 6.13 and you will find the LCD used is standard HD44780 and these you can almost anywhere.
Same goes for Matrix keyboards, search Ebay for both items.
Cheers Bengt
Bengt
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #61 on: April 22, 2010, 02:12:02 PM »
For example: www.cnc4pc.com
regards
Boris
www.poscope.com home of PoKeys USB HID, IO, USB, Ethernet controler and PoScope USB PC oscilloscope
Offline eloid
  •  33 33
« Reply #62 on: April 22, 2010, 06:45:28 PM »
 i was review the manual had question ....
the number of lines that support for lcd is it limited 4 ?....or doest it support more lines
ie looking for 5 lines by 20 eg
like to have 4 lines for dro with a status bar ie
spindle on/off, coolent on/ off,  ide .....mode ...estoped etc
I was looking at cnc4pc site
at the  PoKeys55T do i need the mother to program or will the
PoKeys55T model work with out the motherbrd for programing.
« Last Edit: April 22, 2010, 06:49:27 PM by eloid »
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #63 on: April 23, 2010, 01:47:19 AM »
Hi!
Characters LCDs are standarized to up to 4 lines. You can put more than 1 information in every line.
Motherboard will make your life simpler, but you can leave also without it.
regards
Boris
Offline Bengt
  •  54 54
    • Private CNC site
« Reply #64 on: April 25, 2010, 08:28:16 AM »
Look in PoKeys manual pages 17-18, you can use two displays so add one with the extra lines you need.
I hope I have read correctly if not I am sure Boris will let us know what can be done.
Cheers Bengt
Bengt
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #65 on: April 25, 2010, 09:47:30 AM »
It can not be used 2 displays on the same time, but only one of two. I prefer configuration 2.
As I told already. There can be mora parameters in one line. If you show 2 parameters in every line, 8 parameters could be shown.
regards
Boris
Offline Bengt
  •  54 54
    • Private CNC site
« Reply #66 on: April 25, 2010, 10:01:33 AM »
OK
Can you explain why only one can be used and there is data pins for two displays.
Bengt
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #67 on: April 25, 2010, 10:22:07 AM »
That is the fact. Technical reasons for that.
regards
Boris
Offline Bengt
  •  54 54
    • Private CNC site
« Reply #68 on: April 25, 2010, 03:36:01 PM »
Bengt
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #69 on: April 25, 2010, 05:24:41 PM »
On the other side, you can use up to 255 PoKeyses on one PC.
regards
Boris
