Welcome, Guest. Please login or register.
Did you miss your activation email?
May 21, 2013, 08:07:46 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  PoKeys (Moderator: NeoTO)
| | |-+  How I made my pendant.
Pages: « 1 2 3 4 5 6 7 8 »   Go Down
Print
Author Topic: How I made my pendant.  (Read 11421 times)
Bengt
Active Member
Offline Offline
View Profile WWW
« Reply #60 on: April 22, 2010, 11:12:35 AM »
eloid
Have a look in the PoKeys manual 6.13 and you will find the LCD used is standard HD44780 and these you can almost anywhere.
Same goes for Matrix keyboards, search Ebay for both items.
Cheers Bengt
Logged
Bengt
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #61 on: April 22, 2010, 01:12:02 PM »
For example: www.cnc4pc.com
regards
Boris
Logged
eloid
Active Member
Offline Offline
View Profile
« Reply #62 on: April 22, 2010, 05:45:28 PM »
 i was review the manual had question ....
the number of lines that support for lcd is it limited 4 ?....or doest it support more lines
ie looking for 5 lines by 20 eg
like to have 4 lines for dro with a status bar ie
spindle on/off, coolent on/ off,  ide .....mode ...estoped etc
I was looking at cnc4pc site
at the  PoKeys55T do i need the mother to program or will the
PoKeys55T model work with out the motherbrd for programing.
« Last Edit: April 22, 2010, 05:49:27 PM by eloid » Logged
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #63 on: April 23, 2010, 12:47:19 AM »
Hi!
Characters LCDs are standarized to up to 4 lines. You can put more than 1 information in every line.
Motherboard will make your life simpler, but you can leave also without it.
regards
Boris
Logged
Bengt
Active Member
Offline Offline
View Profile WWW
« Reply #64 on: April 25, 2010, 07:28:16 AM »
Look in PoKeys manual pages 17-18, you can use two displays so add one with the extra lines you need.
I hope I have read correctly if not I am sure Boris will let us know what can be done.
Cheers Bengt
Logged
Bengt
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #65 on: April 25, 2010, 08:47:30 AM »
It can not be used 2 displays on the same time, but only one of two. I prefer configuration 2.
As I told already. There can be mora parameters in one line. If you show 2 parameters in every line, 8 parameters could be shown.
regards
Boris
Logged
Bengt
Active Member
Offline Offline
View Profile WWW
« Reply #66 on: April 25, 2010, 09:01:33 AM »
OK
Can you explain why only one can be used and there is data pins for two displays.
Logged
Bengt
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #67 on: April 25, 2010, 09:22:07 AM »
That is the fact. Technical reasons for that.
regards
Boris
Logged
Bengt
Active Member
Offline Offline
View Profile WWW
« Reply #68 on: April 25, 2010, 02:36:01 PM »
 Huh
Logged
Bengt
borisz
Active Member
Offline Offline
View Profile WWW
« Reply #69 on: April 25, 2010, 04:24:41 PM »
On the other side, you can use up to 255 PoKeyses on one PC.
regards
Boris
Logged
Pages: « 1 2 3 4 5 6 7 8 »   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
