Hello Guest it is April 18, 2024, 11:42:45 PM
Author Topic: How I made my pendant.  (Read 46790 times)
Offline borisz
  •  220 220
    • www.poscope.com
Re: How I made my pendant.
« Reply #50 on: October 22, 2009, 04:29:08 AM »
Try that plugin. It will be officially released in few days.
regards
Boris
« Reply #51 on: October 22, 2009, 02:33:52 PM »
OEM LED 805 has an on/off history of working in recent versions of Mach, depending on the version you have you may wish to try  a slightly older one, think I use 027 on the mill and it works fine.
Spindle I dont have a clue why its not working, you said in the viewer you see it working, is that the Brains you are meaning? If yes then does the possibly the spindle speed override DRO is different in the standard turn screen.
« Reply #52 on: October 22, 2009, 03:33:20 PM »
regards
Boris
Well, it didnt do anything for the MPG, but button presses are now more responsive.
« Reply #53 on: October 22, 2009, 05:15:20 PM »
I am willing to give a different version a try. Know where to find the installer?
« Reply #54 on: October 22, 2009, 05:20:50 PM »
ftp should have them but it seems to be down at the moment..
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #55 on: October 22, 2009, 05:44:29 PM »
Hi!
Latest plugin release: http://www.poscope.com/product.php?pid=3
Added simple LCD, MPG and keys configuration choose PoPendant profile.
regards
Boris
« Reply #56 on: October 28, 2009, 02:46:36 AM »
Nix that on the button presses. Mach is still slow to respond to them. I have to hold them down for a good quarter second before it will respond.
Offline eloid
  •  33 33
« Reply #57 on: April 21, 2010, 10:27:14 PM »
any one have a pendent that uses lcd and matrix touch pad?
look to display dro and step jog infro... on pendant for axis?
Offline borisz
  •  220 220
    • www.poscope.com
« Reply #58 on: April 21, 2010, 10:30:09 PM »
Hi!
Please use plugin for Mach there are all setings there.
regards
Boris
Offline eloid
  •  33 33
« Reply #59 on: April 22, 2010, 11:49:05 AM »
does anyone sell the lcd and matrix key pads that are designed for this interface?
