Hello Guest it is June 09, 2026, 04:05:21 AM
Author Topic: bit coming down as its still moving forward to cut??  (Read 19490 times)
Re: bit coming down as its still moving forward to cut??
« Reply #10 on: June 21, 2009, 08:39:34 AM »
well thank you sooooooo much my husband is up and running now it was the xml file like you said and we noted that for later issues...appreciate your help..THANK YOU!!! ::)
« Reply #11 on: June 25, 2009, 10:03:04 AM »
I don't have the program in front of me but I seem to recall correcting this with a setting perhaps called "connection tolerance" I think it's under the "Extents" tab.  I believe it to be conflicts between how close the chains are and perhaps also the depth of cut and the tool per pass setting.  I posted my query if you want to search for it.
Curtis
Edit:  I now see mine was an issue where I added tabs, it was generating ramps either into or out of the tabs.
« Last Edit: June 25, 2009, 10:05:22 AM by CurtisU »
