Hello Guest it is March 18, 2024, 11:44:48 PM
Author Topic: Forum help  (Read 27196 times)
Forum help
« on: June 03, 2009, 01:19:07 PM »
I need some help understanding the difference between the  two forums: this one and the yahoo mach support group.
I started experiencing problems with the yahoo support group.
my postings do not show up and the search function seem to screen out the messages from the last year.
Does anyone know if the search function of the yahoo group is working properly?
some clarification on what is where will be immensely helpful.
thanks
John
Re: Forum help
« Reply #1 on: June 03, 2009, 04:17:10 PM »
Yahoo is one support forum and this is another, depends on whether you prefer a forum style or a message style which one you use, but both should get you help :)
Re: Forum help
« Reply #2 on: December 22, 2014, 08:00:48 PM »
I have two CNC machines running on MACH3. One is a Milling machine the other is a CNC Router. I have MACH3 profiles setup for each machine and both have worked fine. I have installed the XBOX360 Controller plugin and it works fine on the Mill but I cannot get the Router to operate with the controller. I have enabled the plugin but when I set the buttons and exit the config it does not operate. Will this only work for one profile or am I doing something wrong?
