Hello Guest it is April 19, 2024, 01:32:56 PM
Author Topic: Machscreen overview and download link  (Read 23763 times)
« on: May 23, 2009, 08:40:43 AM »
This board has been set up for the most promising screen designer for Mach to date (5/23/09). It has many capabilities that no designer has had in the past. The design view is similar to what you have seen in screen 3 and 4 but it also has some very powerful added tools. You can view all hotkeys assigned to a screen set in the Hotkey view. You can see a ton of information in the Overview page and most of the information can be edited from this page as well. Size, position, hotkey, etc. The Overview page can also be exported as a csv file and opened in most spread sheets using semicolon for the delimiter. It also has the ability to check your ports and pins (very helpful). I will be posting some screen shots soon and hopefully a tutorial video. Many, many thanks go to Klaus for his work on this.
Thanks soooooooooo much Klaus!!!!!!!!!!
The screen designer can be found at  http://www.kd-dietz.de/index_eng  in the projekt tap at the top. I encourage anyone doing any kind of screen modifying or building to download Klaus's designer and give it a go.
« Last Edit: June 27, 2009, 05:05:06 PM by Chaoticone »
