Welcome, Guest. Please login or register.
Did you miss your activation email?
May 19, 2013, 02:51:34 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  General Mach Discussion
| | |-+  Mach3 simulation
Pages: 1   Go Down
Print
Author Topic: Mach3 simulation  (Read 1402 times)
kak
Active Member
Offline Offline
View Profile
« on: May 19, 2009, 02:09:08 PM »
Hello
If I install the Mach3 on my home PC, without the router or BOB, will it work? I just want to play with screens.
Will it be possible to run a program without BOB and a router?
Adam
Logged
edvaness
Active Member
Offline Offline
View Profile
« Reply #1 on: May 19, 2009, 02:44:40 PM »
Yes you can. Make sure you reboot after install.
Ed
Logged
Ed VanEss
Chris.Botha
Active Member
Offline Offline
wine me.. dine me.. tram my mill for me...
View Profile WWW
« Reply #2 on: May 19, 2009, 02:48:14 PM »
yes.  i test all my programs and screens on my pc inside before i transfer outside to my mill pc.
not having your motor tuning etc setup properly will give your innacurate estimated runtimes and simulation speeds.and so forth, i would find someone running the same hardware as yourself with the same controller and use his xml file in your install.
I test clients files (and mine) like this when they crash their hardware. easier to see visually where something is going wrong that to pour through 100 000 lines of code.
Logged
kak
Active Member
Offline Offline
View Profile
« Reply #3 on: May 19, 2009, 02:57:59 PM »
I have 2 machines in the basement and I live in an apartment on 4th floor - without elevator :-).  So I just need to copy the XML file. Thanks
How about the printerport at home - I dont have one - just USB. Will it still work?
Adam
Logged
Active Member
Offline Offline
Carnoustie, Scotland
View Profile
« Reply #4 on: May 19, 2009, 03:00:22 PM »
You dont need a printer port for simulation.
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
