Hello
Guest
it is
April 18, 2024, 06:02:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach Screens
Screen designer tips and tutorials
Can you make a DRO Read only ?
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Can you make a DRO Read only ? (Read 8507 times)
Overloaded
4,921
on:
May 14, 2009, 05:30:35 PM »
I put this counter DRO and reset button on my TURN screen.
It increments UP 1 per Cycle Start button press. (Actually an external button to INPUT 1).
Can the DRO be made so that it cannot be selected and a have a value entered by an operator ?
RC
Logged
ger21
6,295
Re: Can you make a DRO Read only ?
Reply #1 on:
May 14, 2009, 07:10:32 PM »
This came up a few weeks ago and there were a few workarounds posted. Can't find it though.
I seem to recall something about placing a transparent button on top of it so it can't be accessed? And a way to use a label to display the DRO contents without actually using the DRO.
Logged
Overloaded
4,921
Reply #2 on:
May 14, 2009, 07:20:00 PM »
I'll dig around a bit more with the search utility.
Thanks Ger.
Another question.
What can I do to make the counter see the on screen RUN button press as well as seeing the INPUT 1 from the external button ?
RC
Here is the Brain:
Last Edit: May 14, 2009, 07:23:24 PM by Overloaded
Logged
ger21
6,295
Reply #3 on:
May 14, 2009, 07:30:40 PM »
Change the run button to some VB script and use an OEM trigger for the external button? Then either one should do the same thing?
Logged
Overloaded
4,921
Reply #4 on:
May 14, 2009, 08:08:27 PM »
Changed the Brain input to OEM TRIGGER#1. Works well with the external button.
Cant get the proper script in the VB'd RUN button to cycle the counter DRO.
Can you give me an example of the script/syntax ?
RC
Logged
Kenneth
279
Reply #5 on:
February 03, 2014, 07:46:39 AM »
this may help.
' counts M1001 resets M1002
DRO = GetUserDRO(1011)
SetUserDRO(1011 , (DRO + 1))
While IsMoving()
Wend
Logged
Kenneth
Print
Pages:
1
Go Up
« previous
next »
