Hello Guest it is March 28, 2024, 04:58:01 PM
Author Topic: Gertrude Gets Some!  (Read 250664 times)
« Reply #360 on: November 23, 2014, 03:16:44 AM »
SO all looks like its running ok!
Clip of the path running https://www.youtube.com/watch?v=Pp1ENjXegEU
Clip of the piece done https://www.youtube.com/watch?v=K46d7-Wb5Ak
  •  9,196 9,196
« Reply #361 on: November 23, 2014, 03:42:55 AM »
Absolutely brilliant work Chris - well done you and your mill.  ;)
Offline rcaffin
  •  1,052 1,052
« Reply #362 on: November 23, 2014, 03:56:05 AM »
Yeah, 'orrigh. Not a lot of TIR there either.
(Drools quietly in the background.)
Um - just one Q. How do you make sure there are no wax fragments left on the master before you make the mold? Brush? Vaccuum?
Roger
« Reply #363 on: November 23, 2014, 05:06:36 PM »
it depends what you cutting with, usually i use a tapered ballend and there is not need to clean up with more than a soft paint brush, but with pyramid (3 flute) or profile tools you can get compaction in narrow spaces and this si very much dependant on feed/spindle speed, too slow it compacts, too fast it melts back to the surface, in either case you need a reverse vacuum watergun to clean it up.. dangerous when you have parts with fine detail..
Offline rcaffin
  •  1,052 1,052
« Reply #364 on: November 23, 2014, 06:05:11 PM »
Hum - sounds a bit like dentistry (I think). Light cuts with fast traverse?
Does an air blast help?
Is that also like what a dentist uses?
I am being educated. Thank you.
Roger
« Reply #365 on: November 24, 2014, 07:03:17 PM »
uhhhh.. its called a spot gun. it has a motor that generates a vacuum that creates a very high velocity microstream.. so high that if your fingers cross the stream it injects the water under your skin creating instant "blisters".. you were warned...
https://www.youtube.com/watch?v=bCuxrXCI2QA
Offline rcaffin
  •  1,052 1,052
« Reply #366 on: November 24, 2014, 08:10:33 PM »
Could be a higher pressure than the dentists use ...
Roger
