Hello Guest it is April 26, 2024, 08:38:34 PM
Author Topic: Gertrude Gets Some!  (Read 254315 times)
Offline Bloy
  •  158 158
« Reply #320 on: September 05, 2010, 12:07:35 PM »
Hi Chris,
Fantastic work (the norm for you!)
I see the pic of your webcam for $50 along with the several magnifications.
What brand is that?...And has it been highly modified to suit your purposes?
John Meissner (Bloy)
« Reply #321 on: September 13, 2010, 04:08:11 AM »
Hi John that ais straight off the shelf from ALDI AUstralia :)
« Reply #322 on: September 13, 2010, 04:09:00 AM »
Caro's Coffee Can
Resulting pour
Trimmed on BandSaw and finished on lathe
Roughing Path
Rough that sucker!
Longest roughing I have ever done :(
4 Sided index Paths with blockers
4sided index starts
Indexes with large tool done.. 2.5hours too..
Final small tool indexes for company logo will be done tommorow..
And DOne
« Reply #323 on: December 08, 2010, 09:57:31 PM »
been a bit since i posted guy, sorry. been busy'ish.
I had a nice project to work on here.. saving grannies ring.. this mount is super old. the stone is unrecognizeable cut too. im guessing some windowed rough.
Doing a job which has this much sentiment and very littel actual design characteristics left is always shaky business.. Granny will remember it like the day she first got it, and you need to try live up to that...
wisps of original ring supplied
grab decent picture if possible
bring into Rhino and orient it as best as possible.
adlib the design around what little we do have.
layout for milling.
milled wax.
Cast model.
Some assembly required
and model assembled.
a few before and after shots..
« Reply #324 on: December 08, 2010, 10:58:33 PM »
Wow. Great work Chris. Being an older ring, was the amount of original detail considered to be high for the period?
  •  9,200 9,200
« Reply #325 on: December 09, 2010, 02:18:24 AM »
That is just excellent Chris.
I really look forward to seeing your postings, don't leave it so long next time  ;)
« Reply #326 on: December 09, 2010, 05:05:26 AM »
hey guys, thanks :)
those pieces typically were stamped and assembled. its possible it was hand pierced but unlikely. the level of detail in jewellery has actually gone backwards over the last 20 years. simpler stuff, with cleaner lines seems to be more the order nowdays. But, i service top end lines so in my workspace typically 99.99% of the ring is all about the stone and only marginally about the ring itself. back in the days when diamonds were scarce this was the reverse.
« Reply #327 on: December 09, 2010, 03:25:55 PM »
what a bummer.  :(
« Reply #328 on: December 10, 2010, 08:40:21 PM »
Chris,
As always appreciate this thread and the work your do.
I just went over this whole thread searching for some info since I just started fooling with 3d machining.
Now i have an even greater appreciation for the micro work your doing and the equipment required to do it.
BTW, My little mill can only run  4 IPM, guess i will be doing a lot of reading. ;)
« Reply #329 on: December 10, 2010, 10:07:41 PM »
The videos he made are worth watching, too, if you get time.
