Hello Guest it is April 25, 2024, 05:52:42 PM
Author Topic: Gertrude Gets Some!  (Read 253520 times)
« Reply #160 on: August 16, 2009, 05:33:38 AM »
*cough*    :-[ :-[ :-[ :-[
someone noticed my hub was off center.. yup i blew it, i forgot to probe the tool that cuts the keyhole and its shanks moved my wax .. thought i could get away with it.. but fellow jewelelrs eyes are too sharp.
recut the job.
if ya gonna do it.. do it right i suppose!
« Reply #161 on: August 16, 2009, 05:36:54 AM »
this is the code i used to cutoff the ring ..
G00 Z10.0000
X0.0000 Y6.8000
G01 Z-5.000 F150.0
G17
G03 Y-6.8000 I0.0000 J0.0000
Y6.8000 I0.0000 J0.0000
G00 Z50.0000
G00 Y0.0000
M05
M30
now it occurs to me this should be reasonably simple to setup in mach as a macro that will popup a dialog box and ask me for Green = ((Fingersize/2)-(Cutter Radius)) and Red = (Depth below Z0) then run that code?
« Reply #162 on: August 17, 2009, 07:09:41 AM »
another one...
« Reply #163 on: August 17, 2009, 11:02:53 PM »
here ya go budman.. she came back. looks stunning.
« Reply #164 on: August 18, 2009, 12:42:53 PM »
Indeed it does and thanks for sharing, Chris.
My wife would lose that setting in a heartbeat.  :D
« Reply #165 on: August 19, 2009, 10:30:56 PM »
At $110 000 I bet she would'nt!
or..
she may be refered to as your  late wife.. ;)
« Reply #166 on: August 20, 2009, 11:16:23 AM »
 :D
« Reply #167 on: August 25, 2009, 12:53:00 AM »
few more finished..
this one got lost and eventually found its way back to me.
« Reply #168 on: August 25, 2009, 12:56:05 AM »
this was initially printed because i didnt like the angles involved.. the "thing" that arrived back post casting was not worth even removing from its packet.. i did the job properly on the mill..
lesson learned..
nice ring.. 1.74 ct stone with some mellee..
  •  9,199 9,199
« Reply #169 on: August 25, 2009, 05:35:24 AM »
You certainly have a lot of skills there Chris.
