Home
Downloads
Mach3
Plugins
CAM Post Processors
Screensets
Purchase
Support
Forum
Tutorial Videos
Documentation
Yahoo Group
Mach Wiki
Resources
Contact Us
Links
CNCZone
German Forum
Italian Forum
Korean Forum
Portuguese (Brazil) Forum
Russian Forum (RSK CNCROUTER)
Thai Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email?
May 20, 2013, 12:12:07 AM
1 Hour
1 Day
1 Week
1 Month
Forever
Search:
Advanced search
Select from and to languages
Chinese-simp to English
Chinese-trad to English
English to Chinese-simp
English to Chinese-trad
English to Dutch
English to French
English to German
English to Greek
English to Italian
English to Japanese
English to Korean
English to Portuguese
English to Russian
English to Spanish
Dutch to English
Dutch to French
French to English
French to German
French to Greek
French to Italian
French to Portuguese
French to Dutch
French to Spanish
German to English
German to French
Greek to English
Greek to French
Italian to English
Italian to French
Japanese to English
Korean to English
Portuguese to English
Portuguese to French
Russian to English
Spanish to English
Spanish to French
General CNC Chat
Show"N"Tell ( Your Machines)
Success! Mini Machining Center under Mach3 control - Video link
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
Go Down
« previous
next »
Author
Topic: Success! Mini Machining Center under Mach3 control - Video link (Read 60396 times)
simpson36
Active Member
Offline
on:
May 05, 2009, 03:24:11 PM »
Hi everyone,
After much study and work and help from this forum and other resources, I have my servo powered 4th axis up and running. It does everything I wanted it to do.
In the current arrangement, the mill spindle stays active and still functions as normal.
http://www.youtube.com/watch?v=2KNit__LJE4
For now, some interesting programming is needed along with a custom macro to do the thread passes, but in time, I think Mach3 will have features to make this much better.
I don't plan to make aluminum bolts from round stock. The part just demonstrates the various functions I wanted to get working.
Last Edit: May 06, 2009, 06:49:14 AM by simpson36
derekbpcnc
Active Member
Offline
Reply #1 on:
May 05, 2009, 03:43:49 PM »
Quote from: simpson36 on May 05, 2009, 03:24:11 PM
Hi everyone,
I the current arrangement, the mill spindle stays active and still functions as normal.
For no, some interesting programming is needed along with a custom machro to to the htread passes, but in time, I think Mach3 will have features to make this much better.
Excellent demo, congrats on such a great achievement.
ATB
Derek
You can "chop it off" but can't "chop it on"
Chip
Global Moderator
Offline
Gainesville Florida USA
Reply #2 on:
May 05, 2009, 04:00:42 PM »
Hi, Simpson36
Very Nice job you've done, Show us more if you get time.
Chip
budman68
Master of the Custodial Arts, or better known as:
Global Moderator
Offline
Reply #3 on:
May 05, 2009, 06:16:41 PM »
Beautiful work, my friend, thanks for sharing.
Dave->
vmax549
Guest
Reply #4 on:
May 05, 2009, 07:26:27 PM »
NICE JOB, Just a note on the indexer head . If you plan to use it much machine the housing for seals or orings and fill the cavity with oil to lube the shaft and housing. We used those for a few projects and that helps keep them going without much wear.
simpson36
Active Member
Offline
Reply #5 on:
May 06, 2009, 07:18:41 AM »
Thanks for the compliments.
Vmax,
It's an el-cheapo indexer. So far I have machined the ends only for needle thrust bearings so that I can run with zero clearance. There is no internal cavity, as the spindle just rides in the cast iron bore with a few thou clearance. There really isn't enough meat to cut the ends for seals or for ball or tapered roller bearings. This iteration was just for development purposes . . . i.e. "get 'er done" and have something to work with.
I started with a 640oz-in stepper, went to a 900+ stepper, then to a NEMA23 Servo and now to the final NEMA34 Servo. The new 1,800 line encoder for it arrived yesterday (new model from US Digital)
So, now turning back to the mechanics of it, the only parts coming forward from what you see will be the motor mount and the big timing pulley. The next step in the project is to take a better quality 5C spindle from a Phase II brand indexer (sitting in my garage)
http://www.use-enco.com/CGI/INPDFF?PMPAGE=453&PMITEM=240-3226
. . . . and mount it on sealed ABC3 grade deep groove ball bearings in a new head made from a solid block of metal (I haven't decided on the material). For the level of this project, those bearings are a reasonable compromise. I used them on the original X2 spindle and they have done very well. SKF calls their version 'Precision Plus' . they run in the $50 per bearing range.
bearings
Last Edit: May 06, 2009, 07:20:29 AM by simpson36
coolfox
Active Member
Offline
Reply #6 on:
June 04, 2009, 08:26:34 AM »
Great little machine, well Dun
Can you please tell, how you controll the spindle I mean as an axis or as spindle in mash ?
If it is controlled as an axis do you have an issue with number of steps then milling?
If it is as a spindle how you controll an indexing motion?
Kind regards
Ilia
HimyKabibble
V4 Screen Contributor
Offline
Reply #7 on:
June 04, 2009, 09:27:54 AM »
That is very cool! And just think how much money you can save by making all your own bolts from now on! :-)
simpson36
Active Member
Offline
Reply #8 on:
June 04, 2009, 10:46:10 AM »
Himy,
That's exactly my devious plan. I'm SICK of spending over $1 for a friggin' bolt at the hardware store. I only need to make about 23,000 bolts and I'm breaking EVEN, baby!!!
CoolFox,
As shown in the video, it was acting stricly running as the A axis with all rotations pre calculated, and what you see is the max speed severely limited by the Gecko340.
Later, I learned how to do some 'semi - documented' tricks in Mach that improved the process:
With appreciation for all those who helped me figure it out, let me say it is a pretty slick process. Only thing left to work out is the screwy feed rates. XYZ and A are from different planets in that regard.
Primarily I had to write some VB macros:
One handles the switching the A axis and the spindle using Mache's Swapaxis function.
Another swaps back and the re-homes the A axis (the secret that makes everything work) . . . and zeros the machine and DRO.
Another takes arguments and caclulates threading moves and passes the variables back to mach for use in a gcode program.
Friggin thing is REALLY fun to play with
I just ordered a Viper servo drive that will double the speed to the full 4,000 RPM
Last Edit: June 04, 2009, 11:20:15 AM by simpson36
coolfox
Active Member
Offline
Reply #9 on:
June 05, 2009, 03:43:33 AM »
Simpson36,
Thanks for reply I was asking as I'm in process of upgrading my second lathe Smart&Brown L-model to CNC and wanted to add some active tools with extra Z axis.
I'm jeweller by trade and specialise in making of full eternity rings there turning and milling/drilling process all day (this is my web album
http://www.pixum.co.uk/slide/3540283
in case you interested :-) on the moment I turn blanks on the lathe and then transfer them on 4axis cnc mill (made my self using THK KR slides and Mitsubishi melservo drives motors) for milling/drilling this take time and alighntment not allways perfect.
In regards of spindle homing after axis swap Great idea as I have on bough lathes (The other lathe I have Schaublin 102) servo drives 2.2 kW Servostar CD series with Gold line motors and incremental rotary encoders have K output impulses witch acquire once per revolution! I'm going to try this.
Is it necessary to zeros the machine and DRO after swap home axis? Can you use fixture offset for milling operations?
Pages:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
Go Up
« previous
next »
Jump to:
Please select a destination:
Mach Discussion
=> General Mach Discussion
=> Mach3 under Vista
=> Brains Development
=> Video P*r*o*b*i*n*g
=> Mach Screens
===> Works in progress
===> Finished Screens
===> Flash Screens
===> JetCam screen designer
===> CVI MachStdMill (MSM)
=> Feature Requests
=> Non English Forums
===> Italian
===> French
===> Spanish
===> Chinese
===> German
===> Russian
===> Romanian
===> Japanese
===> Vietnamese
=> FAQs
*****VIDEOS*****
=> *****VIDEOS*****
General CNC Chat
=> Share Your GCode
G-Code, CAD, and CAM
=> LazyCam (Beta)
=> LazyTurn
=> Tempest Trajectory Planner
=> Contec
=> CS-Lab
=> dspMC/IP Motion Controller
=> HiCON Motion Controller
=> Galil
=> Newfangled Solutions Mach3 Wizards
=> Newfangled Mill Wizard
=> Mach3 and G-Rex
=> Mesa
=> Modbus
=> NC Pod
=> PoKeys
=> SmoothStepper USB
=> Sieg Machines
Tangent Corner
=> Tangent Corner
=> Competitions
=> Polls
=> Bargain Basement
Support
=> Downloads
===> XML files
===> Post Processors
===> Macros
===> Tutorials
===> Others
===> Beta Brains
===> Screen Sets
===> Documents
===> MACH TOOL BOX
=> One on one phone support.
Mach4
=> Mach4 pre-Alpha Testing
Loading...
