Hello Guest it is March 29, 2024, 09:05:19 AM
Author Topic: Setting up a 4th Axis (new to CNC)  (Read 9073 times)
« on: May 03, 2009, 04:10:09 PM »
Pardon my newness, but I have run into an immediate snag.  Sorry if there is a post on this already, as I searched but didn't find.  My machine actually uses 2 stepper motors to run the Y axis--one on each side of the gantry.  Each motor is run to its own driver control.  I set up the usual X, Y, and Z axes per setup tutorial videos and also added an A axis (as my second Y).  The A axis motor needs to mimic the Y axis motor.  Can I set this up using Mach 3, or do I have to account for the 4th axis in g-code?
The good news is that the software setup went fine, the parallel port is getting healthy readings, my wiring is fine, and I am able to jog on all 4 axes.  The bad news is that when I try to run a test program, only one side of my table's y axis moves (the side I designated Y--the A axis side gets no code info, so it doesn't move).  Hopefully this is an easy fix as I do not want to tediously fix g-code if I can avoid doing so.  Thanks for the help.
Re: Setting up a 4th Axis (new to CNC)
« Reply #1 on: May 03, 2009, 04:53:05 PM »
Lokk in config, slave axis. You will want to slave the a to the Y.
Offline emi
  •  3 3
« Reply #2 on: July 01, 2013, 07:47:25 AM »
hey i have question about slave axis how do i get these option for X Y Z
 my setup only have one option primary xyza- none and slave xyza-none.
Your screen shows A B C AXIS also?
« Reply #3 on: July 01, 2013, 08:15:34 AM »
Post a screen shot of yours.  It should look just like mine.
Offline emi
  •  3 3
« Reply #4 on: July 01, 2013, 08:18:32 AM »
I have older version i just solve my issue by updating thanks.
« Reply #5 on: July 01, 2013, 08:23:48 AM »
« Reply #6 on: February 03, 2014, 12:03:53 PM »
Hello Brett
I have a 4 axis hotwire setup which I use to cut foam wings for RC airplanes. I am trying to use 1 hotkey to control the simultaneous movement of the Y and A axis, and another to simultaneously move the X and Z axis for jogging purposes. I don't want to use the slaving option because the axis also need to move on their own paths as per the loaded Gcodes when the program is running. Any ideas?
« Reply #7 on: December 27, 2016, 08:32:13 AM »
Did you resolve this question regarding jogging two axis together but yet leaving them independent for the G Code?
