Hello Guest it is April 18, 2024, 10:18:28 AM
Author Topic: Galil controller compatability (what works with the plugin)  (Read 214505 times)
Re: Galil controller compatability (what works with the plugin)
« Reply #70 on: February 07, 2011, 05:57:48 PM »
when you say indexed the motor- not the encoder end i hope.
LOL, No I just had to index the flange that bolts the servo to the machine. What i don't understand is that it worked before I did the motor work. I tried it on the A-axis and I can't get that to turn the wrong way either.  Strange!!! :)
Aero
« Reply #71 on: February 07, 2011, 06:00:51 PM »
It's like the "Dir LowActive" isn't working anymore for some reason in config>ports and pins>motor output, for none of my motors. I reinstalled the plugin, but it had no effect.
Aero
« Reply #72 on: February 07, 2011, 06:06:19 PM »
i think its time you started a new thread. call it aeros help page.
if its not broken yet, fit more gadgets!
« Reply #73 on: February 07, 2011, 06:16:12 PM »
I was thinking the same thing. didn't think I would take up so much space with this :P
Aero
Offline DC
  •  4 4
« Reply #74 on: April 12, 2011, 08:24:54 PM »
I trying to get MACH3 ver 3.043.022 (evaluation version) to work with a Galil 2143 with Galil Plugin V4.4.00
So far Galil Plug in config works and jog is able to move my x, y. and z motors
I loaded Roadrunner gcode and clicked Cycle start button, nothing happens
I looked at the GalilDebug.txt. Nothing unusual with : prompt.
However it looks like nothing got sent out after I clicked on Cycle Start button
Will appreciate it very much if I can get some help.. being kind of new, I am at a lost
Many thanks
« Reply #75 on: September 25, 2011, 03:22:18 AM »
I need help very urgent.
Where (SM) jumper of control DMC 4080 ???
I wish I had a servo digital motor connected to the DMC-4080 and mach3 mill, I have to choose what kind of moter type servo or step. ???
thank you.
udom (thailand)
53000udom@gmail.com
Offline kcrouch
  •  193 193
  • In way too deep!!!
« Reply #76 on: September 25, 2011, 09:11:18 AM »
The jumpers are no longer used. You set the motor type to +/- 2 or +/- 2.5 to select active high or low step and direction.
Please look at "MT" in the manual.
Kenny
Having way too much fun! Something must surely be wrong.
« Reply #77 on: September 27, 2011, 12:45:20 PM »
Now, I use a mach3 plugin and I choose the motor type MT = 2.
I can set a mach3 to close loop fuction.
I was not an analog-digital servo motor, I can select the motor type is MT = 1 or not
Offline kcrouch
  •  193 193
« Reply #78 on: September 27, 2011, 01:35:40 PM »
Closed loop is only valid for a servo system. You must select one of the stepper types in the plugin.
Kenny
« Reply #79 on: September 28, 2011, 11:57:20 AM »
Please help me a little longer. ???
1. I have a digital servo motor.
2. I have a motion control Galil DMC-4143.
3.mach3 software.
I want to make the machine as a close loop.
I've tested as follows.
 - I've set motion drive DMC-4143 by galil tool soft ware (MTA = 2) and set motor type in galil pulgin (Motor type = servo motor) and I jog command from an error on the mach3 then drive DMC-4143.
But if I set motor type in galil pulgin (Motor type step), I used to jog from mach3 it ok. But it was not a close loop.
How do I fix it.
Thanks.
