Hello Guest it is March 28, 2024, 06:57:50 AM
Author Topic: Webcam plugin with low CPU consumption  (Read 57892 times)
Offline Greolt
  •  956 956
Re: Webcam plugin with low CPU consumption
« Reply #50 on: July 04, 2010, 10:59:49 PM »
Klaus
I have been using your video plugin since you first released it here.
Have not updated for a while and have done so now.  V2.08.1
Very good to have the control separate to the main window.
However the "Remember Window Position" is not working for me anymore.
It remembers the width of the window but forgets the height.
Greg
« Reply #51 on: July 05, 2010, 06:47:40 AM »
Hi Greg,
I will fix that.
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #52 on: July 05, 2010, 01:24:06 PM »
Hi Greg,
this is problem is fixed in version V2.8.2 and can be downloaded from my site.
Klaus
Offline Greolt
  •  956 956
« Reply #53 on: July 06, 2010, 06:04:26 AM »
Thank you very much Klaus.
Greg
Offline peu
  •  23 23
« Reply #54 on: August 09, 2010, 06:27:45 PM »
Klaus, Im testing your plugin under win 7 and Im only able to open the crosshair screen, no video feed. Mach default video works ok.
To be able to see the crosshair I need to start the mach default video plugin first, otherwise camera is not detected by your plugin with a "No Camera Found" error messagebox
Is there something I can test?
my Setup:
what version of Mach3 are using 3.042.029
what is your processor speed intel quad core i5
how much RAM do you have 4gb
what display adapter  nvidia 9500gt
and how much Video-RAM are you using 512mb
Windows 7 ultimate
Thanks!!
