Hello Guest it is March 28, 2024, 06:36:42 AM
Author Topic: One driver two motors  (Read 3082 times)
« on: April 06, 2009, 05:21:39 PM »
I have an 8 amp 80v stepper driver, can I run to 4amp step motors on the same axes? or do I need two drivers
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
Re: One driver two motors
« Reply #1 on: April 06, 2009, 07:45:09 PM »
Hi, Spatch
I've seen it done a couple of time's, If it's on a common shaft alignment is critical, It it's on separate shaft's like a dual gantry type install it pretty much a homing issue of needing to home to a hard Stop. As far as I know most would not recommend it as a common practice.
Chip
« Reply #2 on: April 06, 2009, 08:38:56 PM »
Mariss from geckdrive has said in the past that it works OK at lower rpm, but not so well above 300-500rpm.
