Hello Guest it is April 26, 2024, 07:09:52 PM
Author Topic: Issue uninstalling SmoothStepper  (Read 7286 times)
Re: Issue uninstalling SmoothStepper
« Reply #10 on: April 02, 2009, 03:41:59 PM »
Just hooked up an old mobo and HDD that I had here and installed Mach and your xml, it seems to be working fine for me.The voltmeter is certainly showing activity when jogging. I will try and hook up a scope to be 100% sure but the probe is at the workshop but should have a bit of coax I can try with.
 Check that you dont have anything that could be hogging the port such as any documents waiting to be printed etc.
« Reply #11 on: April 02, 2009, 03:44:23 PM »
Shouldn't be anything hogging the port seeing That I made this computer a dedicated pc for the machine with a fresh install of windows xp with nothing else.
« Reply #12 on: April 02, 2009, 03:55:22 PM »
Just hooked up the scope and it is showing a beautiful pulse, well as beautiul as this clapped out scope can show ;D
 Might be worth a try reinstalling Mach over the top of itself as your xml is certainly fine.
