i updated the macro for win7. it doesn't printer to printer but brings up Write.exe
hope this helps someone.
'Macro ToolTable Report
'newer version will poll up To 225 tools And skip Any tool With a description of "empty"
' overwrite file = C:\Documents and Settings\All Users\Desktop\ToolInfo.txt
textFilePath = "C:\mach3\ToolInfo.txt"
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objTextFile = objFSO.CreateTextFile(textFilePath)
Do Until num=225
num=num+1
N = GetToolDesc(num)
D = GetToolParam(num,1)
L = GetToolParam(num,2)
WD= Gettoolparam(num,3)
WL= Gettoolparam(num,4)
If N <>"Empty" Then
objTextFile.WriteLine("*Tool"& num &" * "& N &" *Diameter: "& D &" *Length: "& L &" *Wear Diam"&WD &" *WearLength"&WL & Chr(13) & Chr(10))
Else
End If
Loop
objTextFile.Close
Dim sCOMMAND As String
sCOMMAND="print c:\mach3\toolinfo.txt"
Shell("c:\Windows\System32\write.exe /c" & sCOMMAND)
End
Here is a macro to scan the tool table file and print it out to the local printer. It also write a file copy to the Mach directory called ToolTableReport that can be read from notebook.
You can run it from a button or the MDI
Code Example:
Do Until num=225
num=num+1
If N <>"Empty" Then
Else
End If
Loop
objTextFile.Close
Shell("c:\winnt2\system32\cmd.exe /c" & sCOMMAND)
End
