Hello Guest it is April 25, 2024, 08:38:55 PM
Author Topic: 2.83 ready  (Read 10324 times)
2.83 ready
« on: March 22, 2009, 09:16:22 AM »
I fixed a couple more issues related to the new cutter comp, and a couple related to the use of tool zero and not putting the tool change info in code correctly.
As usual Ill post this here, I hope some of you try it and let me know of any errors. If no problems are found in a couple weeks Ill pass it to Brian to include in the release mach kit.
Update: I just replaced V2.83 with a very minor change.  The original still put the comment in the code that said v2.82. I wont change the v number for so minor a fix, but the code is changed as of  this edit
« Last Edit: March 23, 2009, 12:54:15 PM by Ron Ginger »
Re: 2.83 ready
« Reply #1 on: March 22, 2009, 11:27:30 AM »
Ron,
Will there be a separate version for the Tormach mill?
Mike
Re: 2.83 ready
« Reply #2 on: March 22, 2009, 12:15:12 PM »
No, not needed now. I fixed that in 2.82 so that the wizard figures out the path name.
Re: 2.83 ready
« Reply #3 on: March 22, 2009, 12:24:07 PM »
Thanks Ron - Mike
Offline Greolt
  •  956 956
Re: 2.83 ready
« Reply #4 on: March 22, 2009, 05:52:28 PM »
Ron
Have not had a chance to run any wizards yet but one small thing you might want to fix.
The position of the Inch/MM LEDs which "show on all screens" conflicts with some of the other graphics.
Most notably the electrical shapes page and less so the choose operation page.
Pedantic I know.  ;D ;D ;D
Greg
Re: 2.83 ready
« Reply #5 on: March 22, 2009, 09:20:33 PM »
Ron,
Should MACH VER 3.043.00 be installed before using 283 version???
I'm workring my way up the ladder to 3.043 but seem to keep missing a
wrung on the ladder trying to get there.  ;)
« Last Edit: March 22, 2009, 09:22:43 PM by RICH »
Re: 2.83 ready
« Reply #6 on: March 22, 2009, 09:27:58 PM »
I know about the inch/mm LEDs, its the best I could do since I added them on after all the screens were designed.
The mach version should not matter, as long as its fairly recent- the last year is probably OK. What I fixed for the comp moves was to always make a linear move for the comp exit. That was always OK, after the recent fix its mandatory. So the wizard generated code will run with the old comp fine.
Offline N4NV
  •  398 398
Re: 2.83 ready
« Reply #7 on: March 23, 2009, 12:22:41 PM »
A very minor issue.  When posting the code the second line is:
(Version 2.82)
I just want to make sure I am using version 2.83.  The program indicates V2.83.
Vince
Offline N4NV
  •  398 398
Re: 2.83 ready
« Reply #8 on: March 26, 2009, 06:13:19 PM »
Another issue.  When changing screens, sometimes the last DRO edited shows up behind the current screen.
Vince
Re: 2.83 ready
« Reply #9 on: March 26, 2009, 09:22:05 PM »
That must be some kind of processor or graphics card issue. Nothing in VB or wizards has any control over the display updating. Are you running on a very slow cpu?
