Welcome, Guest. Please login or register.
Did you miss your activation email?
May 20, 2013, 01:21:50 PM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Third party software and hardware support forums.
| |-+  Mach3 and G-Rex
| | |-+  moh_kushly
Pages: 1   Go Down
Print
Author Topic: moh_kushly  (Read 1735 times)
KOSLI
Active Member
Offline Offline
View Profile
« on: March 20, 2009, 01:35:45 AM »
I
How do I reference the digital input #1 in the OEM triggers
I am using G100 controller
Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #1 on: March 20, 2009, 07:12:52 AM »
You will go to config., ports and pins, inputsignals, Oem Trigger and set the pin you want to use there. Then go to config., system hot keys and assign and oem number to the trigger.  See attached pics.
Logged
Grin If you could see the things I have in my head, you would be laughing too. Grin
www.precisionchaos1.com
KOSLI
Active Member
Offline Offline
View Profile
« Reply #2 on: March 21, 2009, 03:31:57 AM »
Thanks Chaoticone for help.    That exactly what i was missing.
But what about the Analouge inputs and outputs ,  Icant find  any place to configure them,   can you help please
Logged
Chaoticone
South Carolina, US
Administrator
Offline Offline
Precision Chaos
View Profile WWW
« Reply #3 on: March 21, 2009, 12:08:07 PM »
Look at the top of this page, support, documentation, G100 Set Up Guide. Some of the normal analog controlled features such as Feed Rate Override will not work with the G100. It was a hope at one time but never matured.
Logged
Pages: 1   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
