Welcome, Guest. Please login or register.
Did you miss your activation email?
June 19, 2013, 11:32:32 AM
Login with username, password and session length
Search:     Advanced search
* Home Help Search Calendar Links Login Register
+  Machsupport Forum
|-+  Mach Discussion
| |-+  VB and the development of wizards
| | |-+  VB syntax
Pages: « 1 2 3   Go Down
Print
Author Topic: VB syntax  (Read 3395 times)
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #20 on: March 22, 2009, 09:14:56 AM »
Jusst another side note:
you have to set the vars before you can use them.
you have this:
'M79.m1s
GetVar (550)
Code"#551=[#550/2]"
You need this:
'M79.m1s
Var1 = GetVar (550)
SetVar (551, (Var1/2))
'When ever you use a "Get" something, you have to set it = to something, OR, put the Get as the parameter of another function.
'for example
SetVar (551, (GetVar (550)/2))
'scott
« Last Edit: March 22, 2009, 09:17:27 AM by poppabear » Logged
Commercial Mach3: Screens (regular and flash), Wizards, Plug-ins, Brains, PLCs, Macros, ATC's, machine build, retrofit and Prototyping
http://sites.google.com/site/volunteerfablab/
MachineMaster
Active Member
Offline Offline
View Profile
« Reply #21 on: March 22, 2009, 10:50:50 AM »
I think you may be missing the fact that
Code"#551=[#550/2]"
does set 551. In reality, I don't need
GetVar (550)
Variable 550 is set in the calling G-code and I could either set 551 as I am doing in the macro or with
#551=[#550/2]
in the G-code following the #550=  line.
Logged
MachineMaster
Active Member
Offline Offline
View Profile
« Reply #22 on: March 22, 2009, 03:21:03 PM »
Hi
You appear to be confusing integers with strings and are showing a integer value within string quotes
The below is not strictly necessary but clearly shows the difference between the 2 types of data you are combining.
(   Str() converts an integer to a String and Val() does the reverse  )
Dim V As Double
Dim s1 As String
V= GetVar (550)
s1 = "G90 G00 X" &Str(V) & " Y" &Str(V)
Code s1
regards
Melee
Actually, when I first set V with
V= GetVar (550)
I am implicitly declaring V as Double. The same is true when I then set V1 with
V1=[V/2]
because the value being set is Double.
Logged
poppabear
S S SYSTEMS, LLC
Global Moderator
Offline Offline
Briceville, TN, USA
View Profile WWW
« Reply #23 on: March 22, 2009, 09:24:14 PM »
Well all righty then, you got it all figured out then
Good luck
scott
Logged
Pages: « 1 2 3   Go Up
Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines Valid XHTML 1.0! Valid CSS!
