Hello
Guest
it is
April 26, 2024, 11:50:32 PM
Guest
Login
Register
Menu
Home
Help
Search
Calendar
Members
Members
View the memberlist
Search For Members
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach SDK plugin questions and answers.
Finished Plugins for Download
Map ALL standard Input and Outputs to a New Diagnostic screen!!
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Map ALL standard Input and Outputs to a New Diagnostic screen!! (Read 29572 times)
Ross
1
Re: Map ALL standard Input and Outputs to a New Diagnostic screen!!
Reply #10 on:
November 07, 2012, 09:31:33 AM »
I am using a highly modified Mach3 screenset but would like to replace the Diagnostics screen with your improved screen. Is there a way to cut and paste between screensets in Screen4?
Thanks for your help,
Ross
Logged
jestah
49
Reply #11 on:
January 15, 2013, 04:49:07 PM »
Scott,
I love your pluging and screen! It has made setting up my first ATC very easy. Could not have done it with out this screen as I could not find much info about mapping oem triggers and other items not already on the standard 1024 screen.
I would like to try making my own screen set so I have spent a few days poking about yours but I think I will give up and admit its well over my head. Could you give me a few clues as to how you went about mapping the io without a brain or macro? Also why do you use this method than a brain or a macro?
Many thanks!
Logged
poppabear
2,235
Briceville, TN, USA
Reply #12 on:
May 25, 2013, 10:08:00 PM »
Jestah,
Thanks, glad you like it!! How it was done was from within the plugin, thus no brains or VB.
Scott
Logged
Denford Miracle
26
Reply #13 on:
December 10, 2015, 05:50:04 PM »
Why didn't anyone answer Ross's question? I would like to do the same thing he wants to do. can you copy and past that page into a different screen set with .lset extension?
OR.... can I use the user defined: 1301 and modifiy my current LED? will the 1301 work?
I guess I can try and see what happens. lmao
Logged
Print
Pages:
1
2
Go Up
« previous
next »
