Hello Guest it is April 25, 2024, 05:02:56 PM
Author Topic: MPG on lpt2 of ss  (Read 6019 times)
MPG on lpt2 of ss
« on: February 25, 2009, 10:07:07 AM »
OK. I've gotten the enable/disable jog to work and the estop to work on the mpg on lpt2 of ss. I still can't actually get it to jog. Any suggestions.
« Last Edit: February 25, 2009, 10:23:40 AM by kdoney »
Re: MPG on lpt2 of ss
« Reply #1 on: February 25, 2009, 11:00:59 AM »
Post your XML for us to look at.
« Reply #2 on: February 25, 2009, 01:18:46 PM »
Here is the xml
« Reply #3 on: February 25, 2009, 05:12:25 PM »
As said on Yahoo, where are you powering the MPG from?
« Reply #4 on: February 25, 2009, 05:50:26 PM »
I assumed that the mpg would be powered from the +5 on lpt2.
« Reply #5 on: February 25, 2009, 05:53:49 PM »
Ok can you give some info, you have a smoothstepper so you dont really have LPT2 as that is a printer port and you dont use that anymore. So you have the USB cable that goes to the smoothstepper then do you have breakout boards connected to Port1 and Port2 on the smoothstepper?
« Reply #6 on: February 25, 2009, 07:09:38 PM »
Yes, I have the SS "Port1" connected to a V1.8 SoundLogic breakout board.
« Reply #7 on: February 25, 2009, 07:13:00 PM »
and you are connecting the MPG to which pins? Where do you have the 5v and 0v wires for the MPG power connected to?
« Reply #8 on: February 25, 2009, 07:41:49 PM »
Found it.
NO POWER IS BEING SUPPLIED TO THE MPG (AS YOU THOUGHT). I thought that it would be supplied by the 5V ttl from the SS board.
Thank you.
