Hello Guest it is April 19, 2024, 06:15:21 PM
Author Topic: Analog inputs.  (Read 5740 times)
Analog inputs.
« on: February 09, 2009, 11:26:01 AM »
My dspMC is capable of 8 Channels Analog Inputs, Range 0..5Volts, 14-bit Resolution. Im curious as to how i would utilize this through Mach3.
It would be ideal for me to be able to utilize some of these inputs in my macros, just wondering if its even possible?
Re: Analog inputs.
« Reply #1 on: February 09, 2009, 11:30:55 AM »
the analog input data is stored in oem dros in mach.  what hardware model do you have 7761 or 7761-Sx or 7761-Mx.
Re: Analog inputs.
« Reply #2 on: February 09, 2009, 11:40:02 AM »
7761S, how do you access oem dros? can you assign a port/pin(input number) to the analog signal?
Re: Analog inputs.
« Reply #3 on: February 09, 2009, 11:53:21 AM »
sorry, the analog inputs are only available in 7761-M.  pls see the webpage www.vitalsystem.com/dspmc
Mach OEM DROs 1320..1327 are reserved for analog inputs.  plugin should be v1.9 or later.
Re: Analog inputs.
« Reply #4 on: February 09, 2009, 12:33:31 PM »
Gotcha. Ill have to do a little work around :)
