Hello Guest it is April 19, 2024, 03:55:22 AM
Author Topic: Attaching a macro to OEM input trigger OEM code 301?  (Read 23932 times)
Re: Attaching a macro to OEM input trigger OEM code 301?
« Reply #10 on: January 28, 2009, 02:20:47 PM »
I would imagine it will be in the ChangeLog when it gets done so just keep an eye on that.
« Reply #11 on: January 28, 2009, 02:51:15 PM »
I guess I'm running out of gas. Where can I find the changeLog file? Is there a way to check for updates to the Mach3 program? I can't seem to find either on March3 Home site.
« Reply #12 on: January 28, 2009, 02:54:53 PM »
Go to the top of this page  and click on the downloads tab then Mach and LazyCAM.
« Reply #13 on: January 28, 2009, 02:57:46 PM »
I'll get the hang of this someday
« Reply #14 on: January 28, 2009, 03:00:22 PM »
Think you seem to have a good handle on it already ;)Hood
« Reply #15 on: February 21, 2009, 05:40:35 AM »
Tony,
 Think Scotts plugin will be very useful to you, you can call up to 15 macros from User LEDs, see here
http://www.machsupport.com/forum/index.php/topic,10399.msg66043.html#msg66043
« Reply #16 on: February 21, 2009, 08:17:03 AM »
Thanks Hood,
I'll buy it and give it a try.
Tony
« Reply #17 on: May 09, 2013, 09:43:30 PM »
Hi tony bullard,
I had the same problem you have and I solve it with MadMach plugin, I use it to trigger more than 10 macros, and it is working good for me. You can tray it .
Good Luck!
« Reply #18 on: August 05, 2018, 07:03:01 PM »
Hey guys, im sorta after the same thing here, i have a pnumatic clamp that i lock with m20 and unlock with m21, i need to activated this with a hardware momentary button that does the opposite to the current state, so if m20 is active pressing the button will toggle it to m21 and visa versa, any help would be appreciated.
« Reply #19 on: August 06, 2018, 07:49:17 AM »
Hi tony bullard,
Good Luck!
Thanks darlly01. I've been using Mach Mad and it works very well. Thanks to Scott!
