Mach Discussion => Brains Development => Topic started by: poppabear on June 25, 2008, 09:02:41 AM
A user had a question on if he wants his m3 and m4 to set a direction output first, then a delay then another output to pull in a contactor, for a larger machine.
Here is a "Brain" that does it.
If using Output1 as your M3, Output2 as M4, and Output3 to pull in your contactor.
Under Ports and Pins, under the spindle tab, you will have to enable "relays" Output1 for M3, and Output2 for M4.
Leave the M3, 4, and 5 macro's in thier original states so they wont conflict with the brain.
The "Timer" delay is set to "1" second you can use Brian editor to modify the timer.
Brain attached,
Scott
I have made up a brain to do somewhat the same.I want to shift high/low
by the value entred in the speed dro or as an m3/m4.I'm using a bob that has relays
for the spindle output 1 & 2.My brain runs fine on my test bench, dwell works ,inputs are required to
activate. However on the machine as soon as it has a spindle on command it bypasses the brain and
activates the relays for the spindle on.Meanwhile the brain is running corectly in the background.?
On the diagnostic page the spindle is running before the output led is lit?
ok this gets wierder.I made up a one line brain that turns on the spindle
with a 5 sec delay.The start relays closed as soon as spinle run pressed.
I then turned off the output and the relay would still close on
a spindle start.I put in a bogus number for the start relays and it still worked.
Now I'm really confused.
hello Freinds;
i am really new Brains user so with Mach 3.
i want to Create a brain for safety:
the brain sholud check in an input is trigged (ON) after an output is done:
Example:
if output #1 is ON i must get an input #2 after 3 seconds.
if i dont get the input after 3 seconds i need to to hold the machine and send a messege Error to the screen.
i want to secure that the my pneumatic piston finish the stroke within 3 seconds and the machine dont continue.
by the way the most important for me is how to send a message to the "Error message: in mach 3 using Brains.
regards;
You will need to do a hybrid solution, using Brains and macropump for your message.
Your Brain would look like this:
OUTPUT1->NO OP->TIMER (set to 3 seconds)->|---AND----|--------- Terminate to a USERLED i.e. 2000
INPUT2--->INVERT---------------------------------->|--BLOCK--|---/
The two inputs both got into an AND block, then the output of the AND block goes to a USERLED that we will use in the MacroPump.
'---Macropump.m1s
Interlock = GetUserDRO(2000) 'some unused user DRO in your setup
PistonInput = GetUserLED(2000) 'the user led in the brain
If PistonInput = 1 And Interlock = 0 Then 'the interlock only allows this to run once per Piston input change of stat
DoOEMButton(1001) 'Push the Feed Hold
Message ("Piston Travel Error") 'Error Message
SetUserDRO(2000,1) 'Set the run once interlock
End
If PistonInput = 0 And Interlock = 1 Then
SetUserDRO(2000,0) 'Clear the interlock
End
'Scott
Hello Scott
Thank you for the reply!
Maybe I did not explain the problem well.
What I need is to Check if I get the input 2 within maximum 3 seconds after the output 1.
It mean if I get input 2 after 2 seconds for me it's ok!!
The 3 seconds it's the timeout for the input.
Your brain and macro pump seems checking if the input 2 came exactly after 3 seconds.
Please let me know your suggestion.
Regards ,
Ghantos
Yes, that is what the solution shows......... PLEASE look at the INVERT on the input2.........
Scott
