Mach Discussion => Video P*r*o*b*i*n*g => Topic started by: ART on November 22, 2007, 12:58:20 PM
Hi Guys
Latest hands from testing.. one is dual strips and hgasd registration errors, but its getting there..
Art
And a fresh model of my hand after cleaning more..
amazing thing is, I recognise the hand as my own.. :)
Art
Ok Art, this is looking great now, how are we going to use this to get a tool path into MACH and then machine it? What are you using? I've got VCarve Pro but I'd like to do some full 3D work like the Vectric Cut 3D. Have any idea about stitching multiple views together?
Hi:
Im afraid its a slow iterative process till we get ther.e At the moment, Im just finished the cleaning algorithms, computeing th tangents of each poin, reprojecting to the denoised surface normals , and decimating the cloud. My next step is to triangulate the cloud, then stl the output. At that point, I think VCarves will load the model and a toolpath can be built. At that point, Ill call MachCloud a done deal.
Its all very nasty math though, so it'll take awhile yet.. But it IS getting better all the time.
The hands above were simply draped in Rhino, no extra cleaning was done in Rhino, so as you can see from the model, the quality is improving quite a bit as I go.. not yet perfect, not as far as preprocessing, I think Im done, now I need to triangulate, then post process
to refinement levels, then Ill be done. Expect it to take a few weeks more anyway..
Art
Hi Art,
You know I was just teasing you. I know how you are with a product and MACH3 is a fine example of how you turn out software. I don't think you'll ever have it completely done as you'll always be tweaking on something in the code. ;D And when someone asks about something to be added of tweaked you'll be there to see if it can be done. I can't wait for the laser to show up so I can try it out and play with it too.
I was wondering, when you did the scan of your hand did you just job the "Y" axis manually? At what rate of speed? I was thinking about putting the camera and the laser on a device like an axis and then turn everything on and have the camera move slowly down the object or across the object and when it hit the limit switch, shut off and the scanned object would be captured to the PC ready for doing to it whatever needs to be done. I thought about this when I first saw the David system.
Keep up the great work!!
Greg
Hi Greg:
No, the scanner makes the moves. For that hand, I told it to do a 1mm Y stepover for 250mm's. It scansn that automatically when you tell it to go.. I have alot of modifications to make once I get it meshing, and I think Ill be able to clean it up quite a bit...
Art
Hi Art,
What's causing the Z-Level "stair stepping" in the scans? Is there a fix or setting that I can implement to minimize this adverse affect?
I have the same problem, I seem to get really great scans except for the "stair stepping. When I build meshes and surfaces I have a lot of averaging and smoothing to do to get a good result to go to CAM with.
Thanks in advance.
-Haik
haik:
As yet, Im unsure, when I have all the pices working, Ill go back and make each one more robust,
I suspect its coming from the scan angle being a bit iff or something.. but I will be correcting for that some
in the post processing steps..
Art
Hey Art
I see no hair on your hands Ha Ha Ha. And Want to let you know it looks GOODS
klmark
You've had a nasty break on that thumb of yours at some point :) . Are you actually scanning your hand or some plaster model of it ? Would coating the surface of the object being scanned with something help? Even something like talc to try and stop rogue reflections?
Hi:
no, thats my actual hand.. :)
I suspect its my math more then reflections.
Art
You are obviously a very patient fellow or do you use it as some sort of meditation whilst scanning. Doesn't it take a fair while to scan ? Very promising results.
Hi:
No, that scan was about 30 seconds or so.. not hard to hold still that long.. :)
Art
30 seconds is pretty fast for such complexity. It becomes more feasible to do multi passes at slightly different angles the quicker a single scan gets. Matching all the different scans then would be more of a headache I suppose.
Hi:
The angles are the same,just more scanning distance , but my math fails in the joining as yet.. still rough and work to do..
Art
I would offer to try and help with the maths if I wasn't so convinced you are probably miles ahead of me and Id' be more of a hinderence having to start right back at first principles.
