Third party software and hardware support forums. => Modbus => Topic started by: Manfred on June 28, 2018, 01:45:38 PM
Hello,
forgive my bad English
I want to connect Mach3 with a Siemens Logo!8 (which ModbusTCP should be able). I want to switch the spindle-frequency-inverter on and off (relay) (http://)via Modbus TCP and set the speed via an analog output 0-10VDC. I'm honest, I don't know exactly what to put where. Tried everything but didn't get it to run. Has anybody got that combination to go?
(http://)
that pic is of the PLC program....you haven't got that far yet.
You need to program Mach to talk over TC/IP Modbus BEFORE you start worrying about programming the PLC.
excuse
I activated Modbus TCP in Mach3 and tried to set.
I haven't figured out what I've got wrong yet.
more pictures. i have not been able to add them at once
Hello Manfred,
you will also have to do some Brain in Mach to write to the modbus.
Thomas
