Third party software and hardware support forums. => Mach3 and G-Rex => Topic started by: lavalais on January 13, 2018, 01:16:38 AM
I have been using my inc machine for several years now shut it down yesterday, started it up today loaded my program turned on the controller didn't turn on so i opened it up changed the fuse, put everything back together, started the controller tried using the keyboard keys
for the x,y,and z axis nothing happened so i spent may hold day trying to figure out how or what happened I can move the machine with the jog control and everything works fine but the keyboard controls are of no use. What am I missing .
Have you accidentally clicked on the Jog ON/OFF Ctrl-Alt-J button ?
Thanks ! I gave that a try it didn't seem to work on my key board i pressed the Cltr - Alt keys i know the key board is working because i can use the tab button to bring up the jog control. other than pressing the Cltr- Alt button i tried several ways and something did happen it went up in the z axis but when i stopped it and tried the other direction nothing happened it didn't even respond to the up key anymore.
OK Now I feel as though i did something else because now it won't respond to the jog buttons on the control i get no movement now.
On the Mach3 main screen is the Jog ON/OFF button illuminated (green around border) ?
Thanks! That apparently was the problem everything has returned to normal. I just want to say how appreciative I am for this knowledge base and what you guys do to help.
Excellent, I am pleased the problem is resolved.
