Mach Discussion => Finished Plugins for Download => Topic started by: X-TRA78 on January 06, 2018, 08:05:30 AM
Title: Plugin to run script on Shutdown
Post by: X-TRA78 on January 06, 2018, 08:05:30 AM
Hello,
For my new ScreenSet (Sinumerik OP47), i have written a plugin with which one can execute a script (*. vbs or * hta) when Mach3 is shut down.
Maybe someone else need such a function and that's why I uploaded the plugin.
The Script should be stored in the following location.:
{Mach3InstallPath}\Macros\{Profile}\Shutdown(x).(vbs|hta)
It will look first for Shutdown(x).hta and if Not found, then Shutdown(x).vbs.
You can use multiple shutdown scripts, e.g. one to shut down Windows and one to modify XML-Profile and reboot Mach3 etc.
1.Shutdown.vbs
2.Shutdown2.vbs
3.Shutdown3.vbs
4....
The number of the shutdown script (x), can be set by using the "SetShutdownScriptNum (wNum)" subroutine.
Code:
Declare Sub SetShutdownScriptNum Lib "ShutdownScript" (ByVal Num As Integer)
The plugin does not need to be activated via the "config Plugins" menu.
(http://)
currently two parameters are passed to the shutdown script.
Parameter 1 = path of Mach3 install folder
Parameter 2 = profile name
Post by: X-TRA78 on January 06, 2018, 08:29:30 AM
Example for Shutdown.vbs to get the Params and wait until Mach3 shut down is finish.
Code:
Dim iCount
Dim iArg
Dim sProfileName
Dim sMach3Path
iCount = wScript.Arguments.Count
if iCount >= 2 then
sMach3Path = wScript.Arguments(0)
sProfileName = wScript.Arguments(1)
Else
End If
Set svc=getobject("winmgmts:root\cimv2")
sQuery="select * from win32_process where name='mach3.exe'"
set cproc=svc.execquery(sQuery)
iniproc=cproc.count
Do While iniproc = 1
    wscript.sleep 200
    set svc=getobject("winmgmts:root\cimv2")
    iniproc=cproc.count
Loop
set cproc=nothing
set svc=nothing
' Mach3 has been fully shut down.
' now modify XML-Profile or something else.
Title: Re: Plugin to run script on Shutdown
Post by: Tweakie.CNC on January 06, 2018, 11:08:12 AM
That sounds very interesting, thanks for sharing.
Title: Update: Plugin to run script on Shutdown
Post by: X-TRA78 on January 08, 2018, 03:55:33 AM
Hello,
here is a new version of the plugin (v0.2.2.106).
I've adjusted the search paths for the script and added a new feature that lets you set the search path for the script.
In addition, the name of the first ScreenSet will be passed to the script.
The following function can now be used to set the search path
Code:
Declare Sub SetShutdownScriptPath Lib "ShutdownScript" (ByVal szPath As String)
SetShutdownScriptPath "C:\Mach3\ScreenSetMacros\Test.set\Scripts"
if no search path has been set, it is first searched in dir "{Mach3Path}\Macros\{Profile}\" for the file and then in dir "{Mach3Path}\ScreenSetMacros\{ScreenSetName}.set\"
These three parameters are now passed to the script:
Parameter 3 = main screenset name (currently only first loaded ScreenSet)
