Mach Discussion => FAQs => Topic started by: Traxide on November 14, 2017, 12:37:43 AM
Have built a CNC Router connected to a Desktop via Parallel port using mach 3 software running on Windows XP. Loaded Demo Gcode "Roadrunner" and everything works great, but the size of the routing is only 12mm x 12mm. What have I done wrong in the Setup.
I'm guessing that your machine is interpreting the Gcode as mm units when the RoadRunner (being a Yankee!) is in inches.
Try on the MDI screen coding G20 <enter> and run the code again. G20/G21 are used to allow the Gcode interpreter to use either inches or mm's as units.
Thanks for the information, I will try this tomorrow morning
