Third party software and hardware support forums. => dspMC/IP Motion Controller => Topic started by: dunnitagain on September 16, 2017, 03:02:37 PM
After Upgrading from Mach4 2480 to 3481 and Plugin 2.01.70 . Mach wont stay connected to the dspmc , Error says dspmc not found , then it will hook up for about 5 seconds and show it
in the History Line . It shuttles back and forth so fast you can see it read out. Mach 2480 and old plugin were solid as a Rock!
I cant figure it out? Is it in Config or my Ethernet hardware?
you only need update mach4 if required. should not need newer plugin. do you still have the old plugin? If you upgrade the plugin, you must update the firmware as well which is a risky thing as it may brick the controller if not done properly. the safest way to upgrade the firmware is to completely disconnect the controller from all plugs and leave only green power and Ethernet plugs connected. when new firmware is flashed successfully, disconnect the green power plug and reconnect after few seconds and make sure the new version shows up in the vsiDeviceManager on network scan.
My plugin was 112515. Are you saying that I need to Update the firmware on my box ? Or do I need to revert my Pluggin ? What about the newer features of the newest Plugin?
yes in order to use new features and bug fixes you will need to update the controller firmware. follow the instructions I mentioned in the previous post as well as in the vsiDeviceManager documentation which describes the steps to flash a new firmware.
Reflashed the box to the new firmware version and it works great now!
I just received an new box with firmware 10.10 FPGA E901. I change the IP address with the VSI device manager from the default . Rescan the network and my controller is there at the new address. When I plug the controller into my network, it is assigned a DHCP address. I cannot find anything in the VSI documentation about DHCP disable.
currently there is no option to disable DHCP.
in your dhcp server, have you tried define static address for the dspmc unit?
My system will not stay connected. Brand new dspMC out of the box firmware 10.10 FPGA E901 boot loader 0.06 Hardware 7762, Mach 4 3481, plugin 2.01.72
Every time I enable my system, I get system arm error and it disables.
have you connected earth ground and signal ground according to diagram
http://www.vitalsystem.com/portal/motion/AnalogDriveConnections.pdf
Yes, this unit is sitting on my bench for configuration for new machine. When I turn on the logging, I am see System Arm Error DSPMC:283.
If I disable all inputs and outputs in the machine configuration, system will stay enabled
make sure the limit sensors are not triggered. you can verify that in the mach4 maitainence tab.
There are no I/o connected to the system yet, I have only enabled 2 inputs and 2 outputs,
Enable #0 - [P11] Output 0,
Enable #1 - [P11] Output 1,
Input #0 - [P11] Input 15
we can remote login on monday and see what the problem is. you can download and install teamviewer and send the login information to support at vitalsystem,com.
Can do. Tks
