Mach Discussion => Mach Screens => Works in progress => Topic started by: Graham Waterworth on July 16, 2017, 04:50:56 PM
Here is a super simple screen for running a mill or router. All the clutter is gone and its all you need to run a machine.
It was designed to use in education where all they need is to load some code and press go.
See what you think.
I will upload the files later when I have finished tweaking.
Graham
Graham
Mach 3 or 4?
Will it support 4 axis?
Another Graham
Hi Graham,
this one in Mach3 but we are working on a Mach4 one now, these are only 3 axis but later we will do a 4 axis set.
Graham
Here we have the Mach4 version screen shot.
Excellent work Graham.
I like simple :)
Graham
Are the files available for the Super Simple Screen for Mach3? I am a super simple type guy that can use a super simple screen. ;D
Very nice Mach 4 screen.
Mike
Hi Graham,
Is the Super Simple Screen for Mach3 .zip file available for download please ?
Tweakie, Mike,
It is now.
The screen set is provided as is, no changes will be made to it, it was done for use in schools where only the minimum amount of controls are needed and as such is great for just loading and running g-code.
With the windows menus turned off it makes it very hard to play with the settings and as such not much can go wrong. Or that is the theory, I am sure some kid will prove me wrong ;D
